Installation & Licensing
Cant install AutoCAD 2011 on Windows XP
2 REPLIES 2
Johnnzki
637 Views, 2 Replies
These is the log in %TEMP% folder. Help me please..
2012/7/12:08:15:33 john GFORCE6100PM-M2 === Setup started on GFORCE6100PM-M2 by john ===
2012/7/12:08:15:49 john GFORCE6100PM-M2 === Setup ended ===
2012/7/12:08:15:43 john GFORCE6100PM-M2 === Setup started on GFORCE6100PM-M2 by john ===
2012/7/12:08:17:55 john GFORCE6100PM-M2 Install DirectX 9.0 Runtime Succeeded
2012/7/12:08:19:45 john GFORCE6100PM-M2 Install Autodesk Material Library 2011 Succeeded
2012/7/12:08:20:01 john GFORCE6100PM-M2 Install AutoCAD 2011 Failed Installation aborted, Result=1603
2012/7/12:08:21:28 john GFORCE6100PM-M2 Rollback Autodesk Material Library 2011 Failed Installation aborted, Result=1603
2012/7/12:08:21:29 john GFORCE6100PM-M2 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1620
2012/7/12:08:21:35 john GFORCE6100PM-M2 === Setup ended ===
2012/7/12:08:36:04 john GFORCE6100PM-M2 === Setup started on GFORCE6100PM-M2 by john ===
2012/7/12:08:36:14 john GFORCE6100PM-M2 === Setup ended ===
2012/7/12:08:36:08 john GFORCE6100PM-M2 === Setup started on GFORCE6100PM-M2 by john ===
2012/7/12:08:36:57 john GFORCE6100PM-M2 Install Microsoft Visual C++ 2008 Redistributable (x86) Succeeded
2012/7/12:08:37:12 john GFORCE6100PM-M2 Install DirectX 9.0 Runtime Succeeded
2012/7/12:08:37:43 john GFORCE6100PM-M2 Install Autodesk Material Library 2011 Succeeded
2012/7/12:08:38:22 john GFORCE6100PM-M2 Install Autodesk Material Library 2011 Base Image library Succeeded
2012/7/12:08:38:35 john GFORCE6100PM-M2 Install AutoCAD 2011 Failed Installation aborted, Result=1603
2012/7/12:08:38:58 john GFORCE6100PM-M2 Rollback Autodesk Material Library 2011 Base Image library Succeeded
2012/7/12:08:39:46 john GFORCE6100PM-M2 Rollback Autodesk Material Library 2011 Succeeded
2012/7/12:08:39:46 john GFORCE6100PM-M2 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2012/7/12:08:39:47 john GFORCE6100PM-M2 Rollback Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1619
2012/7/12:08:39:52 john GFORCE6100PM-M2 === Setup ended ===
2012/7/12:08:43:07 john GFORCE6100PM-M2 === Setup started on GFORCE6100PM-M2 by john ===
2012/7/12:08:43:17 john GFORCE6100PM-M2 === Setup ended ===
2 REPLIES 2
emily.xu
in reply to: Johnnzki
16xx error is generally user rights issue. Don't know if the user "john" has admin right, but I would suggest you try to use your system default admin user "administrator" to install the product, and close any other applications, especially, anti-virus and firewall including the background processes.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
Johnnzki
in reply to: emily.xu
Can you teach me how to make "john" as administrator, my computer has 3 user accounts because my aunt and brother use it too. So help me.
Administrator Productivity
