These is the log in %TEMP% folder. Help me please..
2012/7/12:08:15:33 john GFORCE6100PM-M2 === Setup started on GFORCE6100PM-M2 by john ===
2012/7/12:08:15:49 john GFORCE6100PM-M2 === Setup ended ===
2012/7/12:08:15:43 john GFORCE6100PM-M2 === Setup started on GFORCE6100PM-M2 by john ===
2012/7/12:08:17:55 john GFORCE6100PM-M2 Install DirectX 9.0 Runtime Succeeded
2012/7/12:08:19:45 john GFORCE6100PM-M2 Install Autodesk Material Library 2011 Succeeded
2012/7/12:08:20:01 john GFORCE6100PM-M2 Install AutoCAD 2011 Failed Installation aborted, Result=1603
2012/7/12:08:21:28 john GFORCE6100PM-M2 Rollback Autodesk Material Library 2011 Failed Installation aborted, Result=1603
2012/7/12:08:21:29 john GFORCE6100PM-M2 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1620
2012/7/12:08:21:35 john GFORCE6100PM-M2 === Setup ended ===
2012/7/12:08:36:04 john GFORCE6100PM-M2 === Setup started on GFORCE6100PM-M2 by john ===
2012/7/12:08:36:14 john GFORCE6100PM-M2 === Setup ended ===
2012/7/12:08:36:08 john GFORCE6100PM-M2 === Setup started on GFORCE6100PM-M2 by john ===
2012/7/12:08:36:57 john GFORCE6100PM-M2 Install Microsoft Visual C++ 2008 Redistributable (x86) Succeeded
2012/7/12:08:37:12 john GFORCE6100PM-M2 Install DirectX 9.0 Runtime Succeeded
2012/7/12:08:37:43 john GFORCE6100PM-M2 Install Autodesk Material Library 2011 Succeeded
2012/7/12:08:38:22 john GFORCE6100PM-M2 Install Autodesk Material Library 2011 Base Image library Succeeded
2012/7/12:08:38:35 john GFORCE6100PM-M2 Install AutoCAD 2011 Failed Installation aborted, Result=1603
2012/7/12:08:38:58 john GFORCE6100PM-M2 Rollback Autodesk Material Library 2011 Base Image library Succeeded
2012/7/12:08:39:46 john GFORCE6100PM-M2 Rollback Autodesk Material Library 2011 Succeeded
2012/7/12:08:39:46 john GFORCE6100PM-M2 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2012/7/12:08:39:47 john GFORCE6100PM-M2 Rollback Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1619
2012/7/12:08:39:52 john GFORCE6100PM-M2 === Setup ended ===
2012/7/12:08:43:07 john GFORCE6100PM-M2 === Setup started on GFORCE6100PM-M2 by john ===
2012/7/12:08:43:17 john GFORCE6100PM-M2 === Setup ended ===
16xx error is generally user rights issue. Don't know if the user "john" has admin right, but I would suggest you try to use your system default admin user "administrator" to install the product, and close any other applications, especially, anti-virus and firewall including the background processes.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Can you teach me how to make "john" as administrator, my computer has 3 user accounts because my aunt and brother use it too. So help me.
