hey guys.
for some reason i cant install revit architecture 2012 on my computer. i download it and then when i intend to install it then it just says no. as soon as i push install it hits me back with "instalation complete, some product failed to install".. what the **** is up?
i installed autoCAD architecture no problem.. and is that maybe the problem? can i only use one product on this student agreement?
i actually deleted a arc and tried agein and nothing changed... i really could juse some help 🙂
Post the installation log so we can see where the failure is. It's most likely a prerequisite installer failing.
2012/6/27:21:14:51 Notandi RAGGI === Setup started on RAGGI by Notandi ===
2012/6/27:21:14:51 Notandi RAGGI Launch
2012/6/27:21:16:04 Notandi RAGGI === Setup ended ===
2012/6/27:21:14:52 Notandi RAGGI === Setup started on RAGGI by Notandi ===
2012/6/27:21:14:52 Notandi RAGGI Launch
2012/6/27:21:16:05 Notandi RAGGI PageOpen LaunchDialog
2012/6/27:21:17:44 Notandi RAGGI PageOpen LicenseDialog
2012/6/27:21:18:22 Notandi RAGGI PageOpen ProductInfoDialog
2012/6/27:21:19:11 Notandi RAGGI PageOpen ProductSelectionDialog2
2012/6/27:21:19:44 Notandi RAGGI PageOpen FullProgressDialog
2012/6/27:21:19:44 Notandi RAGGI Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Notandi\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/6/27:21:19:54 Notandi RAGGI Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2012/6/27:21:19:54 Notandi RAGGI Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Notandi\AppData\Local\Temp\vcredist_x86_2010.log
2012/6/27:21:19:56 Notandi RAGGI Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/6/27:21:19:57 Notandi RAGGI Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2012/6/27:21:19:57 Notandi RAGGI PageOpen InstallCompleteDialog
2012/6/27:21:23:46 Notandi RAGGI === Setup ended ===
2012/6/27:21:23:59 Notandi RAGGI === Setup started on RAGGI by Notandi ===
2012/6/27:21:23:59 Notandi RAGGI Launch
2012/6/27:21:24:24 Notandi RAGGI === Setup ended ===
2012/6/27:21:24:24 Notandi RAGGI PageOpen LaunchDialog
2012/6/27:21:25:04 Notandi RAGGI PageOpen LicenseDialog
2012/6/27:21:25:11 Notandi RAGGI PageOpen ProductInfoDialog
2012/6/27:21:25:54 Notandi RAGGI PageOpen ProductSelectionDialog2
2012/6/27:21:26:05 Notandi RAGGI PageOpen FullProgressDialog
2012/6/27:21:26:05 Notandi RAGGI Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Notandi\AppData\Local\Temp\vcredist_x86_2010.log
2012/6/27:21:26:07 Notandi RAGGI Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/6/27:21:26:07 Notandi RAGGI PageOpen InstallCompleteDialog
2012/6/27:21:27:45 Notandi RAGGI === Setup ended ===
2012/6/27:22:50:38 Notandi RAGGI === Setup started on RAGGI by Notandi ===
2012/6/27:22:50:38 Notandi RAGGI Launch
2012/6/27:22:51:48 Notandi RAGGI === Setup ended ===
2012/6/27:22:50:39 Notandi RAGGI === Setup started on RAGGI by Notandi ===
2012/6/27:22:50:39 Notandi RAGGI Launch
2012/6/27:22:51:49 Notandi RAGGI PageOpen LaunchDialog
2012/6/27:22:52:35 Notandi RAGGI PageOpen LicenseDialog
2012/6/27:22:52:39 Notandi RAGGI PageOpen ProductInfoDialog
2012/6/27:22:53:18 Notandi RAGGI PageOpen ProductSelectionDialog2
2012/6/27:22:53:32 Notandi RAGGI PageOpen FullProgressDialog
2012/6/27:22:53:32 Notandi RAGGI Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Notandi\AppData\Local\Temp\vcredist_x86_2010.log
2012/6/27:22:53:35 Notandi RAGGI Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/6/27:22:53:35 Notandi RAGGI PageOpen InstallCompleteDialog
2012/6/27:22:54:58 Notandi RAGGI === Setup ended ===
2012/6/27:22:55:58 Notandi RAGGI === Setup started on RAGGI by Notandi ===
2012/6/27:22:55:58 Notandi RAGGI Launch
2012/6/27:22:56:22 Notandi RAGGI === Setup ended ===
2012/6/27:22:56:22 Notandi RAGGI PageOpen LaunchDialog
2012/6/27:22:57:09 Notandi RAGGI PageOpen LicenseDialog
2012/6/27:22:57:29 Notandi RAGGI PageOpen ProductInfoDialog
2012/6/27:22:59:31 Notandi RAGGI PageOpen ProductSelectionDialog2
2012/6/27:22:59:38 Notandi RAGGI PageOpen FullProgressDialog
2012/6/27:22:59:39 Notandi RAGGI Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Notandi\AppData\Local\Temp\vcredist_x86_2010.log
2012/6/27:22:59:41 Notandi RAGGI Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/6/27:22:59:41 Notandi RAGGI PageOpen InstallCompleteDialog
2012/6/27:23:52:03 Notandi RAGGI === Setup ended ===
2012/6/28:11:11:10 Notandi RAGGI === Setup started on RAGGI by Notandi ===
2012/6/28:11:11:10 Notandi RAGGI Launch
2012/6/28:11:12:11 Notandi RAGGI === Setup ended ===
2012/6/28:11:11:12 Notandi RAGGI === Setup started on RAGGI by Notandi ===
2012/6/28:11:11:12 Notandi RAGGI Launch
2012/6/28:11:12:11 Notandi RAGGI PageOpen LaunchDialog
2012/6/28:11:13:33 Notandi RAGGI PageOpen LicenseDialog
2012/6/28:11:13:53 Notandi RAGGI PageOpen ProductInfoDialog
2012/6/28:11:14:53 Notandi RAGGI PageOpen ProductSelectionDialog2
2012/6/28:11:15:11 Notandi RAGGI PageOpen FullProgressDialog
2012/6/28:11:15:11 Notandi RAGGI Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Notandi\AppData\Local\Temp\vcredist_x86_2010.log
2012/6/28:11:15:14 Notandi RAGGI Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/6/28:11:15:16 Notandi RAGGI PageOpen InstallCompleteDialog
2012/6/28:11:27:20 Notandi RAGGI === Setup ended ===
2012/6/30:02:40:02 Notandi RAGGI === Setup started on RAGGI by Notandi ===
2012/6/30:02:40:02 Notandi RAGGI Launch
2012/6/30:02:40:51 Notandi RAGGI === Setup ended ===
2012/6/30:02:40:03 Notandi RAGGI === Setup started on RAGGI by Notandi ===
2012/6/30:02:40:03 Notandi RAGGI Launch
2012/6/30:02:40:52 Notandi RAGGI PageOpen LaunchDialog
2012/6/30:02:42:04 Notandi RAGGI PageOpen LicenseDialog
2012/6/30:02:42:09 Notandi RAGGI PageOpen ProductInfoDialog
2012/6/30:02:46:31 Notandi RAGGI PageOpen ProductSelectionDialog2
2012/6/30:02:46:41 Notandi RAGGI PageOpen FullProgressDialog
2012/6/30:02:46:41 Notandi RAGGI Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Notandi\AppData\Local\Temp\vcredist_x86_2010.log
2012/6/30:02:46:43 Notandi RAGGI Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Very easy.
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
