Installation & Licensing
Cant find Request Code for Maya 2009 after reaching activation limit
4 REPLIES 4
876 Views, 4 Replies
I reached the limit of activations with my maya 2009.
Now the support (CaseNo:07982006.) is asking me for a request-code that i'am not able to find.
Before i get to the point in the activation process where it should show me the registration code , it tells me that i reached the limit of activations and stops the activation process.
I also cant get into the help menu cause maya has no demo mode.
It seems that all this methods are only working for newer versions of maya.
Thank you for your help!
4 REPLIES 4
camilo.lemos
Hi halifaxx,
Here is a set of alternatives to help you locate your request code.
Let me know if this works for you!
Camilo Lemos
in reply to: camilo.lemos
No!
It seems that the tips are also for newer mayas.
Problem is still there!
Please help! I cant work!
jessica.t
Hi there!
Autodesk Maya Complete 2009 does not generate a request code for manual activations.
If you could please provide the ethernet address of the computer you are using we will be able to activate the product for you.
Jessica Thrasher
Administrator Productivity
