Installation & Licensing
Cant download 3ds max - windows 8 64bit
4 REPLIES 4
elai950
985 Views, 4 Replies
i tried the install button, the download now button and the browser.
the install stop after a 5 min and saying that my internet connection is worng, and its really fine .
the download now button says the same like the install button .
and the browser download in the self-extract its stucks after 1.5gb
What can i do to fix it ??
the firewall is off and the UAC as well .
4 REPLIES 4
TravisNave
in reply to: elai950
Welcome to the community.
See if you can download it manually from Matt, the virtual assistant.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Autodesk Forums:
elai950
i already done that and still its freezing when it gets to 1.78gb
philip.s
Hello Elai!
Can you try disabling your firewall, and/or turning off any antivirus software, and try re-downloading?
elai950
in reply to: philip.s
I succed download and install 3ds max . i just tried again the install button and it worked . i dont know why i didnt do nothing . im pretty sure that if ill want to download another software that will come back ...
But now i have another problem with 3ds max .
when i starting it up its says error :
standard startup file ray3rc is not found
what the problem ? i dont understand ...
(another problem that i found and solved is that with the updated nvidia driver 3ds max wont start , it will crush after the logo appear . the solution is to downgrade the driver[not very good solution])
Administrator Productivity
