HI
I am trying to unstall the Insfrastructure Design Suite Ultimate 2014 and was not able to unsinstall map3d
I want to unsinstall the Suite in order to install it again in Spanish, it was installed in English
THANK YOU VERY MUCH FOR YOUR HELP
Solved by dembkod. Go to Solution.
try running the windows uninstall
through contral panel
DarrenP
hi,
I tried uninstalling from the control panel and I couldn't because Map 3D doesn't appear at software list I received this error when I tried to install the Spanish trial version to activate it
Hello. Before you try to install, try to uninstall MAP using the MSfixit tool:
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
This tool is good for uninstalling and cleaning residual traces. It may help here.
Thank you for taking part in our community!
hello dembkod
I tried using MSfixit and apparently did correctly uninstalling
installed the map 3D 2013 only (6 apps are installed with it)
and now I receive this error, cannot access a acadres.DLL probably while clining up the registers I deleted too much.
I tried importing back the registers to the saved version and the program doesn't open, no message is given,
PROBABLY i AM BACK TO THE STRATING POINT AFTER TWO DAYS OF NIGHTMARE
I have openned again FixIt and it says that I have two versions of Map 3D 2014 installed, apparently it didn't uninstall properly since I started encountering this problem when I tried to install the Spanish Trial Version of Map 3D and I had already installed the English Version
FINALLY I GOT IT!!!!
MAp 3D 2014 is reinstalled now and I need to know the procedure to change it fron Emglish to Spanish Version
PLease I need help with this
