Installation & Licensing
Cannot uninstall/reinstall Autodesk Inventor View
11 REPLIES 11
Message 1 of 12
EScales
2351 Views, 11 Replies
I have a client that tried to install Autodesk Inventor View 2012 (32-bit) on a WinXP SP3 machine.  There was some sort of problem during the install, so they tried to unistall in from the Control Panel.  It seemed to uninstall it ok, until they try to reinstall in and it thinks that it is already installed and they cannot select it.  I did a screen share with them and went through the whole clean unistall procedure, but it did not help.  I tried the Windows Installer Cleanup Utility, but Inventor View doesn't appear in the list.  They tried using RevoUnistaller, but again the Inventor View doesn't even appear in the list.  I've gone through the registry several times and there doesn't seem to be any traces of any Autodesk stuff in there, but it will not reinstall.  What do I do now?  HELP!!!
11 REPLIES 11
Message 2 of 12
TravisNave
in reply to: EScales
Have you tried the Autodesk's clean uninstall process?  Make sure also that the installed program directory is deleted.
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Autodesk Forums:
Message 3 of 12
If installs 64bit Inventor View 2012, please try to search and delete them
HKEY_CLASSES_ROOT\Installer\Products\D9816D67466100400000FD2CEE33E7CA
HKEY_CLASSES_ROOT\Installer\Products\D9816D67466100400010FD2CEE33E7CA
If, 32bit, this key:
HKEY_CLASSES_ROOT\Installer\Products\D9816D67236100400000FD2CEE33E7CA
HKEY_CLASSES_ROOT\Installer\Products\D9816D67236100400010FD2CEE33E7CA
Message 4 of 12
  I just would like to install Inventor Viewer. Tried with Version 2012, 2013 and 2014 and
always get the same message (see attachment). (64-Bits system)
The only difference within the message is the Temp Folder name.
The extraction came out just fine, but when goin' further during the installation
this is the message I get. And it does appear at the beginning of the installation process.
2 things you should know before replying to me...
-I have never installed an Autodesk software on this computer before.
(Double checked the Control panel, registry, Autodesk folders on this computer, and found nothing).
-I have Solid Edge ST4, Team Center 8.1 with UGS NX 7.0, SolidWorks 2012 Edrawing, installed on my working station.
Any help would be appreciated.
thanks
Mario
Message 5 of 12
YoyoYue
Hi Mario,
I am afraid some files are missing during the extraction.
Do you mind downloading the package and try it again?
Yoyo
Message 6 of 12
in reply to: YoyoYue
Do you really think I got the same problem with 3 bad downloads of 3 different versions?
I have checked the folders, and the file it seems to be lookin' is really there (InventorView.msi)
  Also, I want to point out that since I had problems installing it on my Desktop Computer at work, I
tried to install the 2013 version of the software on another user's Desktop computer, and it installed
flawlessly.
  So I'm guessing there might be a ghost or something in my desktop computer to refuse installing it,
but can't figure out what the problem is...
Hope someone can help me out how to deal with this...
thanks Yoyo for your comment though.
Mario
Message 7 of 12
YoyoYue
Thanks for your quick response.
I have already contacted our developer to look into it.
Will get back to you once we find a solution.
Yoyo
Message 8 of 12
srlake31470
I have had this same issue with Maya 2014 and 2013.  When I started to have issues with 2014 I uninstalled it via both the autodesk uninstall, as well as the control panel.  And as the original poster said, I ran cccleaner after contacting autodesk for help.  I've gone into the registry as well and have deleted key upon key including the 3 that someone had suggest, as well as went into c://programdata/autodesk.
Still nothing!  I keep trying to install Maya 2013 and 2014 and with both, it says it's installed already.  There has got to be a way to disable that "looking" for previous install and just install over whatever this bloody program is seeing.
For crying out loud I have been working on this for 5 days now and still unable to fix it.
Message 9 of 12
YoyoYue
in reply to: srlake31470
I have talked with our developers, and they think a possible reason is because of the anti-virus software, here is an example (http://upandready.typepad.com/up_and_ready/2013/01/trend-micro-the-system-cannot-open-the-device-or-...).
So would you please check if you have any anti-virus software installed?
If it still does not work, here is another possible reason. Perhaps your C drive or more specific, the Temp folder is encrypted. If the first solution does not fix the issue, do you mind checking if your C drive (Temp folder) is encrypted?
Yoyo
Message 10 of 12
Hi, I'll ask the technician here to help me with our Anti-Virus software (Trend Micro Security Agent).
Since I can't de-Activiate it on my work station. But I can't see I'm the only one here that can't install it
since we all ahve the same Anti-Virus Software.
  As per your 2nd solution, if I have to check for an encrypted Temp folder, I really don't know how to
find out if it is encrypted. So I'll have to also check this out with our technician this week.
thanks, and I'll try to let you know later.
Mario
Message 11 of 12
TravisNave
Trend Micro is the culprit lately in a lot of install fails.
Autodesk Forums:
Message 12 of 12
wedxza
I have the same prob with inventor 2014, then I read http://blog.jtbworld.com/2012/09/how-to-solve-problem-when-setup-says.html
I went to HKEY_CLASSES_ROOT\Installer\Products\ and looked at the description, I found the file realted with Inventor, started with 195or something, it I deleted that, and found out I can reinstall it
Administrator Productivity
