Installation & Licensing
Cannot uninstall Inventor 2012
6 REPLIES 6
mihai20
2002 Views, 6 Replies
I recently tried to install Inventor 2012 but during the installation process I got a prompt to close Windows Explorer before continuing. I had the option to close it and reboot it after the install or continue and restart the pc after installation, so I chose to continue without closing Explorer. Soon after that I got another error and the installation closed but I had the Inventor 2012 icon on my desktop but I couldn't open it because it gave an error. I tried reinstalling but then in the autorun it said that Inventor 2012 is already installed, all I could do was install the other parts. I closed it, uninstalled all Autodesk products (I had Inventor 2011 installed) and tried again with the same result. I followed the instructions from Autodesk on how to perform a clean uninstall and still the same result: Autodesk Inventor 2012 already installed. I used Revo Uninstaller for these tasks, deleted all the folders and registry keys. I also tried a removal tool to remove all Autodesk products from my pc but it didn't detect any. I tried installing Inventor directly from the .msi file, skipping the autorun, but I get error 1606 cannot access network path /bin. I tried solutions found on the web to resolve the error (deleting or editing registry keys and automated fix) but it didn't work.
So this is my predicament. What can I do? I am out of options, the only thing left that I can think of is to format drive C and close Explorer when the installer tells me to. Maybe there's an easier way? Please help!
6 REPLIES 6
TravisNave
in reply to: mihai20
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
If that doesn't work, Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Autodesk Forums:
glydrfreak
i installed the file to my portable hard drive accidentally. i removed it from the hard drive, and now i can't install it to my desktop because of this: (see attachment)     how to i do this?
mihai20
in reply to: TravisNave
The Clean Up Utility did the trick. Thank you!
TravisNave
in reply to: glydrfreak
glydrfreak, try using one of the methods listed in my links above.
mihai20, glad you are fixed up! Smiley Happy
Autodesk Forums:
glydrfreak
i can't figure out how to run it. it's not in the start menu anywhere.
TravisNave
It gets installed to the root of the start menu.
Autodesk Forums:
Administrator Productivity
