I cannot see or accept the Next Button or the Accept or Reject license agreement options on the AutodeskDesignRevSetup.exe welcome screen, and the window is not resizeable. Chaning my display resolution does not help. How do I get a binary with the the buttons and optionsn visible, or the window resizable so I can install on my Windows XP Pro desktop?
Solved by Stonehenge. Go to Solution.
On your screenshot, lower right corner, is the edge of the button you seek: what display resolution are you running in WIndows?
Also, the graphics on the pop-up look broken: are you attempting an online installation, or did you download the full installer, or using a disk?
After a reboot, the program window is enlarged and the buttons now visible. I have no idea what changed, as yesterdays' install attempt was also done just after rebooting.
Nevertheless, Autodesk should issue programs with RESIZABLE windows.
Problem was caused by AutoSizer a very nice program which has a bug that causes it to interfere with windows it wasn't explicitly told to control.
