Installation & Licensing
Cannot install Revit - Download Error Connection has expired
4 REPLIES 4
camilafletcher
2117 Views, 4 Replies
I have tried to install Revit several time in my new computer and I keep getting few error messages.
Download Error    Connection has expired. Please reconnect to site.
Download Error    VCREDIST2005X86    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{ECA69465-EE12-4899-8A73-3DEB79CCE824}/VCREDIST2005...
Does any one knows how to fixed it?
Thank you,
Camila
4 REPLIES 4
TravisNave
in reply to: camilafletcher
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Or you can download the trial.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
camilafletcher
in reply to: TravisNave
HI There,
I appreaciate your help but it did not work.
I have windows 8. I have tried the student version of 2014 and 2015. The free trial version and the virtual agent version. This last one says the file is corrupted. Can any one help?Thank you.
My firewall is off.
Any other help?
Thank you,
Camila
Do I have to uninstall from my other computer in order to have Revit installed in the new compute?
Thank you,
Camila
camilafletcher
I got this error message when trying to install the Free Trial
CRC failed in Utilities\SDK\RevitSDK.exe
Unexpected end of archive
Administrator Productivity
