I have the same problem, but my pc is a HP with Windows 7 Home Premium 64 bit, 4 gb en Ram 750 Gigas DD, and intel dual core 2.4 Ghz.
The steps are:
Put DVD and automatic detection.
But when I click a Install Autocad 2011
show in screen this error "Cannot install on the current operating system?"
Why show this problem if I have the requirements?
AutoCAD 2011 has 3 DVD’s:
Disk one is 32-bit Disk 1 of 2.
Disk two is 64-bit Disk 1 of 2.
Disk three is 32-bit and 64-bit disk 2 of 2.
Make sure you are inserting the 64-bit DVD for 64-bit operating systems or the 32-bit DVD for 32-bit operating systems.
"My problem is with the installation. When the download is complete a message pops up and says install, so i install. once that is done another screen comes up where it says install the product, create deployments, install tools and utilities and read the documentation. so i select install the product and the message appears "you cannot install this product on the current operating system." (this is for AutoCAD 2011)"
I am having this EXACT same problem and I didn't see any solution.
I am trying to install the 30 day Trial version. I have tried to install the trial versions of both AutoCAD and AutoCAD Lite 2011 to no avail. I am running Windows 7 Home Premium.
Someone help!
Me too! I've got the AutoCAD 2011 Student Version. It came with 2 discs. One disc is labeled "64-bit", disc 2 is labeled "32 bit & 64 bit".
I'm running Windows XP Pro SP3 (32 Bit), and when I try to install from the setup.exe on disc 1, it says "You cannot install this product on this Operating System". I can't find any setup files on disc 2.
What is going on?
For Windows XP 32-bit you will need:
32-bit Disk 1 of 2 (32-bit installer is on this disk)
and
and
Thanks for the info, Douglas. How can I exchange the discs I have for this version?
The media you have should contain all three DVD’s. If not you should contact your reseller or the Autodesk Business Center for replacement media.
@cinepro wrote:Me too! I've got the AutoCAD 2011 Student Version. It came with 2 discs. One disc is labeled "64-bit", disc 2 is labeled "32 bit & 64 bit".
Also, students can download Student Version (32-bit or 64-bit) for free 36-month student license from http://www.autodesk.com/edcommunity
We moved your post to a new thread.
Hello. I am facing the same problem trying to install autocad architecture 2011. H/W and S/W config are OK, but I still receive the error message.
Just spent 6 hours on this...any help would be greatly appreciated...thanks,
Post a screen capture of your system specifications here.
I overcame this problem with the Alias package by locating the actual install file and running that rather than the setup file.
