Please someone help I have tried several times to install and it keeps giving me this error: "Installation complete. Some products failed to install"
Basicly it does not install anything. Here is the log file:
2014/4/12:23:53:21 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/12:23:53:21 Sergio SERGIO-HP Path_Length: 151
2014/4/12:23:53:21 Sergio SERGIO-HP Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/12:23:53:21 Sergio SERGIO-HP Launch
2014/4/12:23:53:21 Sergio SERGIO-HP CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-29566159 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/12:23:53:21 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AI6BFD.tmp
2014/4/12:23:57:00 Sergio SERGIO-HP === Setup ended ===
2014/4/12:23:53:23 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/12:23:53:23 Sergio SERGIO-HP Path_Length: 151
2014/4/12:23:53:23 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AI6BFD.tmp
2014/4/12:23:53:23 Sergio SERGIO-HP Launch
2014/4/12:23:55:06 Sergio SERGIO-HP Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/12:23:56:59 Sergio SERGIO-HP Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/12:23:57:00 Sergio SERGIO-HP PageOpen LaunchDialog
2014/4/13:00:01:24 Sergio SERGIO-HP PageOpen LicenseDialog
2014/4/13:00:01:24 Sergio SERGIO-HP PageOpen ProductInfoDialog
2014/4/13:00:01:24 Sergio SERGIO-HP PageOpen ProductSelectionDialog2
2014/4/13:00:01:29 Sergio SERGIO-HP PageOpen FullProgressDialog
2014/4/13:00:01:30 Sergio SERGIO-HP Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/4/13:00:09:32 Sergio SERGIO-HP Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/4/13:00:09:32 Sergio SERGIO-HP Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/13:00:11:32 Sergio SERGIO-HP Install DirectX® Runtime Succeeded
2014/4/13:00:11:32 Sergio SERGIO-HP Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:00:35:38 Sergio SERGIO-HP Download User Pause Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:00:35:38 Sergio SERGIO-HP Download Paused Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:00:35:46 Sergio SERGIO-HP Download User Resume Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:01:14:41 Sergio SERGIO-HP Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:01:14:41 Sergio SERGIO-HP Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/4/13:01:14:43 Sergio SERGIO-HP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/13:01:14:44 Sergio SERGIO-HP PageOpen InstallCompleteDialog
2014/4/13:05:38:35 Sergio SERGIO-HP === Setup ended ===
2014/4/13:06:16:43 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:06:16:43 Sergio SERGIO-HP Path_Length: 151
2014/4/13:06:16:43 Sergio SERGIO-HP Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/13:06:16:43 Sergio SERGIO-HP Launch
2014/4/13:06:16:43 Sergio SERGIO-HP CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-29566159 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/13:06:16:43 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AI50FC.tmp
2014/4/13:06:16:49 Sergio SERGIO-HP === Setup ended ===
2014/4/13:06:16:46 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:06:16:46 Sergio SERGIO-HP Path_Length: 151
2014/4/13:06:16:46 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AI50FC.tmp
2014/4/13:06:16:46 Sergio SERGIO-HP Launch
2014/4/13:06:16:48 Sergio SERGIO-HP Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/13:06:16:49 Sergio SERGIO-HP PageOpen LaunchDialog
2014/4/13:06:21:14 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:06:21:14 Sergio SERGIO-HP Path_Length: 151
2014/4/13:06:21:14 Sergio SERGIO-HP Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/13:06:21:14 Sergio SERGIO-HP Launch
2014/4/13:06:21:14 Sergio SERGIO-HP CommandLine
2014/4/13:06:21:14 Sergio SERGIO-HP An instance of setup is already running. Only one instance of setup can run at a time.2014/4/13:06:21:17 Sergio SERGIO-HP === Setup ended ===
2014/4/13:06:17:00 Sergio SERGIO-HP PageOpen LicenseDialog
2014/4/13:06:17:00 Sergio SERGIO-HP PageOpen ProductInfoDialog
2014/4/13:06:17:00 Sergio SERGIO-HP PageOpen ProductSelectionDialog2
2014/4/13:06:17:05 Sergio SERGIO-HP PageOpen FullProgressDialog
2014/4/13:06:17:06 Sergio SERGIO-HP Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/4/13:06:17:06 Sergio SERGIO-HP Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/13:06:19:20 Sergio SERGIO-HP Install DirectX® Runtime Succeeded
2014/4/13:06:19:21 Sergio SERGIO-HP Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:06:21:36 Sergio SERGIO-HP Download User Pause Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:06:21:36 Sergio SERGIO-HP Download Paused Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:06:21:38 Sergio SERGIO-HP Download User Cancel Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:06:21:39 Sergio SERGIO-HP PageOpen InstallCompleteDialog
2014/4/13:06:21:42 Sergio SERGIO-HP Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:06:21:45 Sergio SERGIO-HP === Setup ended ===
2014/4/13:06:21:48 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:06:21:48 Sergio SERGIO-HP Path_Length: 151
2014/4/13:06:21:48 Sergio SERGIO-HP Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/13:06:21:48 Sergio SERGIO-HP Launch
2014/4/13:06:21:48 Sergio SERGIO-HP CommandLine
2014/4/13:06:21:48 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AIFF16.tmp
2014/4/13:06:21:58 Sergio SERGIO-HP === Setup ended ===
2014/4/13:06:21:52 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:06:21:52 Sergio SERGIO-HP Path_Length: 151
2014/4/13:06:21:52 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AIFF16.tmp
2014/4/13:06:21:52 Sergio SERGIO-HP Launch
2014/4/13:06:21:59 Sergio SERGIO-HP === Setup ended ===
2014/4/13:06:22:45 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:06:22:45 Sergio SERGIO-HP Path_Length: 151
2014/4/13:06:22:45 Sergio SERGIO-HP Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/13:06:22:45 Sergio SERGIO-HP Launch
2014/4/13:06:22:45 Sergio SERGIO-HP CommandLine
2014/4/13:06:22:45 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AIDE7C.tmp
2014/4/13:06:22:51 Sergio SERGIO-HP === Setup ended ===
2014/4/13:06:22:48 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:06:22:48 Sergio SERGIO-HP Path_Length: 151
2014/4/13:06:22:48 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AIDE7C.tmp
2014/4/13:06:22:48 Sergio SERGIO-HP Launch
2014/4/13:06:22:52 Sergio SERGIO-HP === Setup ended ===
2014/4/13:06:25:32 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:06:25:32 Sergio SERGIO-HP Path_Length: 151
2014/4/13:06:25:32 Sergio SERGIO-HP Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/13:06:25:32 Sergio SERGIO-HP Launch
2014/4/13:06:25:32 Sergio SERGIO-HP CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-29566159 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/13:06:25:32 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AI6A85.tmp
2014/4/13:06:25:35 Sergio SERGIO-HP === Setup ended ===
2014/4/13:06:25:33 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:06:25:33 Sergio SERGIO-HP Path_Length: 151
2014/4/13:06:25:33 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AI6A85.tmp
2014/4/13:06:25:33 Sergio SERGIO-HP Launch
2014/4/13:06:25:34 Sergio SERGIO-HP Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/13:06:25:35 Sergio SERGIO-HP PageOpen LaunchDialog
2014/4/13:06:25:41 Sergio SERGIO-HP PageOpen LicenseDialog
2014/4/13:06:25:41 Sergio SERGIO-HP PageOpen ProductInfoDialog
2014/4/13:06:25:41 Sergio SERGIO-HP PageOpen ProductSelectionDialog2
2014/4/13:06:25:47 Sergio SERGIO-HP PageOpen FullProgressDialog
2014/4/13:06:25:47 Sergio SERGIO-HP Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/4/13:06:25:47 Sergio SERGIO-HP Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/13:06:27:04 Sergio SERGIO-HP Install DirectX® Runtime Succeeded
2014/4/13:06:27:04 Sergio SERGIO-HP Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:07:23:52 Sergio SERGIO-HP Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:07:23:52 Sergio SERGIO-HP Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/4/13:07:23:53 Sergio SERGIO-HP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/13:07:23:53 Sergio SERGIO-HP PageOpen InstallCompleteDialog
2014/4/13:10:27:38 Sergio SERGIO-HP === Setup ended ===
2014/4/13:13:35:58 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:13:35:58 Sergio SERGIO-HP Path_Length: 151
2014/4/13:13:35:58 Sergio SERGIO-HP Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/13:13:35:58 Sergio SERGIO-HP Launch
2014/4/13:13:35:58 Sergio SERGIO-HP CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-29566159 /PK 657F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/13:13:35:58 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AID71C.tmp
2014/4/13:13:36:03 Sergio SERGIO-HP === Setup ended ===
2014/4/13:13:36:00 Sergio SERGIO-HP === Setup started on SERGIO-HP by Sergio ===
2014/4/13:13:36:00 Sergio SERGIO-HP Path_Length: 151
2014/4/13:13:36:00 Sergio SERGIO-HP Current Directory C:\Users\Sergio\AppData\Local\Temp\_AID71C.tmp
2014/4/13:13:36:00 Sergio SERGIO-HP Launch
2014/4/13:13:36:01 Sergio SERGIO-HP Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/4/13:13:36:03 Sergio SERGIO-HP PageOpen LaunchDialog
2014/4/13:13:36:14 Sergio SERGIO-HP PageOpen LicenseDialog
2014/4/13:13:36:14 Sergio SERGIO-HP PageOpen ProductInfoDialog
2014/4/13:13:36:14 Sergio SERGIO-HP PageOpen ProductSelectionDialog2
2014/4/13:13:37:18 Sergio SERGIO-HP PageOpen FullProgressDialog
2014/4/13:13:37:19 Sergio SERGIO-HP Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/4/13:13:37:19 Sergio SERGIO-HP Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/13:13:39:38 Sergio SERGIO-HP Install DirectX® Runtime Succeeded
2014/4/13:13:39:39 Sergio SERGIO-HP Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:14:39:29 Sergio SERGIO-HP Download Error Maya <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:15:11:44 Sergio SERGIO-HP Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/4/13:15:11:44 Sergio SERGIO-HP Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/4/13:15:11:45 Sergio SERGIO-HP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
The problem is a failed download. You should probably use the virtual assistant to download the product.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
