I have just installed autocad student version without a problem however when I try to install inventor student version the installation seems to begin, then windows explorer pops up a message, when I click OK the installation stops and inventor indicates that it has failed to install.
See below for the message that windows gives me,
Windows ® Installer. V 5.0.9200.16384
msiexec /Option <Required Parameter> [Optional Parameter]
Install Options </package | /i> <Product.msi> Installs or configures a product /a <Product.msi> Administrative install - Installs a product on the network /j<u|m> <Product.msi> [/t <Transform List>] [/g <Language ID>] Advertises a product - m to all users, u to current user </uninstall | /x> <Product.msi | ProductCode> Uninstalls the product Display Options /quiet Quiet mode, no user interaction /passive Unattended mode - progress bar only /q[n|b|r|f] Sets user interface level n - No UI b - Basic UI r - Reduced UI f - Full UI (default) /help Help information Restart Options /norestart Do not restart after the installation is complete /promptrestart Prompts the user for restart if necessary /forcerestart Always restart the computer after installation Logging Options /l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile> i - Status messages w - Nonfatal warnings e - All error messages a - Start up of actions r - Action-specific records u - User requests c - Initial UI parameters m - Out-of-memory or fatal exit information o - Out-of-disk-space messages p - Terminal properties v - Verbose output x - Extra debugging information + - Append to existing log file ! - Flush each line to the log * - Log all information, except for v and x options /log <LogFile> Equivalent of /l* <LogFile> Update Options /update <Update1.msp>[;Update2.msp] Applies update(s) /uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode> Remove update(s) for a product Repair Options /f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode> Repairs a product p - only if file is missing o - if file is missing or an older version is installed (default) e - if file is missing or an equal or older version is installed d - if file is missing or a different version is installed c - if file is missing or checksum does not match the calculated value a - forces all files to be reinstalled u - all required user-specific registry entries (default) m - all required computer-specific registry entries (default) s - all existing shortcuts (default) v - runs from source and recaches local package Setting Public Properties [PROPERTY=PropertyValue]
Consult the Windows ® Installer SDK for additional documentation on the command line syntax.
Copyright © Microsoft Corporation. All rights reserved. Portions of this software are based in part on the work of the Independent JPEG Group.
You might see if you can update your MSIEXEC and redownload the Autodesk installation files. It seems it is not passing the correct information to the installer and throwing an error. Is this a download install, a media install, or a deployment install?
Hi all,
I have also encountered this problem.
I struggled for half a day... had tried many solutions found online... but they did not work out...
Finally I looked at the Setup Log file and found the problem was cause by the C++ 2005 redistributable...
Looking at the Setup.ini file, two lines of parameters were deleted!
Everything became fine then (an extra 'Yes' to click during installation)!!!
I am so happy with this solution and wish this help!
Cheers.
