Installation fails when trying to connect to internet. My internet connection is fine.
Do you have very high security on your internet? Some websites you cannot access?
I don't believe my internet settings are a problem. I can access all sites without problems. I seem to recall having similar problems with this install in the past. Can vaguely recall autodesk having an alternative install package.
Ended up downloading the MSI zip file and installing that way. Thanks for your help anyway.
Sorry, our time zones are way different so by the time I read your message it was quite late. Well I am glad you came right. Please let me know if you get stuck again
Hi, I'm having the same problem but cannot find the download link for the MSI, can anyone point me in the right direction please? Thanks
Dan
Hi that's great, thanks very much for that! I've successfully installed but it's crashing shortly after launch. Can anyone advise whether it's supported on Windows 2008? The release notes only mention Windows 7 but 2008 has the same underlying architecture so presumably yes?
thanks
Dan
Sir, I'm not an expert but you can try the following steps:
1. Win+D (Desktop)
2. Right click the Icon of Design Review 2013
3. Select Properties
4. In the Compatibility tab check the box that says "Run this program in compatibility mode for:"
5. Select Windows 7
6. Click Apply then Ok
now try again if it works if not, repeat steps 1 - 5 then also check "Run this program as an administrator"
I hope this helps...
