Very frustrating - Appreciate any assistance
I have uninstalled, deleted folders, deleted registry keys per Acad Instructions till I'm blue in the face. At 3 of 8, the Internal Error 2738 appears, select OK, Install bar progresses for awhile then ends with msg: Failed.
Install log:
2013/5/16:19:09:09 Haans CAROL-PC === Setup started on CAROL-PC by Haans ===
2013/5/16:19:09:09 Haans CAROL-PC Launch
2013/5/16:19:09:24 Haans CAROL-PC === Setup ended ===
2013/5/16:19:09:18 Haans CAROL-PC === Setup started on CAROL-PC by Haans ===
2013/5/16:19:09:18 Haans CAROL-PC Launch
2013/5/16:19:09:24 Haans CAROL-PC PageOpen LaunchDialog
2013/5/16:19:09:30 Haans CAROL-PC PageOpen LicenseDialog
2013/5/16:19:09:34 Haans CAROL-PC PageOpen ProductInfoDialog
2013/5/16:19:10:13 Haans CAROL-PC PageOpen ProductSelectionDialog2
2013/5/16:19:11:47 Haans CAROL-PC PageOpen FullProgressDialog
2013/5/16:19:11:47 Haans CAROL-PC Installing DirectX Runtime: J:\AutoCAD_Civil_3D_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/5/16:19:12:40 Haans CAROL-PC Install DirectX Runtime Succeeded
2013/5/16:19:12:40 Haans CAROL-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="J:\AutoCAD_Civil_3D_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/16:19:13:19 Haans CAROL-PC Install Autodesk Material Library 2013 Succeeded
2013/5/16:19:13:19 Haans CAROL-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="J:\AutoCAD_Civil_3D_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/16:19:13:45 Haans CAROL-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/5/16:19:13:45 Haans CAROL-PC Installing Microsoft Visual Basic Power Packs 10.0: J:\AutoCAD_Civil_3D_2013_English_Win_32bit\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe /q /l C:\Users\Haans\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2013/5/16:19:13:51 Haans CAROL-PC Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2013/5/16:19:13:53 Haans CAROL-PC Installing AutoCAD Civil 3D 2013: TRANSFORMS="J:\AutoCAD_Civil_3D_2013_English_Win_32bit\x86\en-us\C3D\C3D.mst;C:\Users\Haans\AppData\Local\Temp\_AI65B4.tmp\x86\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="J:\AutoCAD_Civil_3D_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/5/16:19:28:50 Haans CAROL-PC Install AutoCAD Civil 3D 2013 Failed Installation aborted, Result=1603
2013/5/16:19:28:50 Haans CAROL-PC Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2013/5/16:19:29:24 Haans CAROL-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/5/16:19:30:16 Haans CAROL-PC Rollback Autodesk Material Library 2013 Succeeded
2013/5/16:19:30:16 Haans CAROL-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Solved by normans. Go to Solution.
Many thanks to all that responded (0). Especially those Acad staff:
"Get answers to your Installation and licensing questions in our Installation & Licensing forum. Autodesk staff will be actively monitoring this forum, working with the existing community to answer your installation and licensing questions.
Autodesk Product Support:":
For those that exp same:
I was able to install C3D after uninstalling McAfee. I used a removal tool called MCPR.exe which removed all McAfee components. I was using info from TS45252 and Diagnostic start in msconfig (only service selected was Win Installer).
After restarting from msconfig I noticed that there was still 3 McAfee services running. This and frustration are what lead me to uninstall McAfee. C3D installed without a problem.
Cheers
Thanks for the update. We always recommend that installations are started on the local hard drive with local admin rights, UAC off, and anti-virus disabled. Beyond that, there are typical issues resulting from prerequisite failures or including service packs with the install.
This is a peer support forum of users helping users. I hope your post helps someone in the future with this problem. Thanks for contributing!
