Hi there,
I am trying too install Autodesk 2009 onto my computer but am having difficultys with the port 80 issue. All i can find on google and such is things about 'Apache' which i dont want ! When installing Autodesk the test comes back and fails as port 80 is blocked but port 80 is used by PID 4 which is actually 'SYSTEM - NT Kernel & System'. I desperately need this sorting as soon as possible so if anyone has any idea how to get around this it would be very much appreciated,
Many Thanks,
Jac Powell
Autodesk 2009 products are not be tested and supported with Windows 7 OS.
see : http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=14056350&siteID=123112
so I would suggest you to change your OS to ensure your programs run correctly if you want use 2009 products.
