Installation & Licensing
Cannot Install AutoCAD Net Framework
1 REPLY 1
421 Views, 1 Reply
I have used Net Framework cleanup tool and it has not been successful.
Error is as per below, please assist.
  2013/3/8:02:21:22 Andrew HAL9000 === Setup started on HAL9000 by Andrew ===
2013/3/8:02:21:22 Andrew HAL9000 Launch
2013/3/8:02:21:22 Andrew HAL9000 [Error: 1060] The specified service does not exist as an installed service.
2013/3/8:02:21:22 Andrew HAL9000 [Error: 6] The handle is invalid.
2013/3/8:02:21:24 Andrew HAL9000 PageOpen LaunchDialog
2013/3/8:02:21:28 Andrew HAL9000 PageOpen LicenseDialog
2013/3/8:02:21:32 Andrew HAL9000 PageOpen ProductInfoDialog
2013/3/8:02:21:43 Andrew HAL9000 PageOpen ProductSelectionDialog2
2013/3/8:02:22:38 Andrew HAL9000 PageOpen FullProgressDialog
2013/3/8:02:22:38 Andrew HAL9000 Installing .NET Framework Runtime 4.0: C:\AutoCADD\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/3/8:02:23:10 Andrew HAL9000 Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
Seems to be that people have a common problem with this but not a common solution.  Please help, as I've already wasted hours.  Thank you,
1 REPLY 1
TravisNave
Install .NET 4 manually from Microsoft and then remove the prerequisite check for it from the setup.ini.
See my solution here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
Administrator Productivity
