I have uninstalled all visual c++ redist packs, running the automatic installer gives the error "Installation complete, some files failed to install".
Here is logfile
2014/7/22:04:28:22 === Setup started on SASHA by Luke === 2014/7/22:04:28:22 Path_Length: 148 2014/7/22:04:28:22 Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US 2014/7/22:04:28:22 Launch 2014/7/22:04:28:22 CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US_... /SN 900-31630700 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/7/22:04:28:22 Setup Windows update reboot is pending 2014/7/22:04:28:27 === Setup ended === 2014/7/22:04:41:28 === Setup started on SASHA by Luke === 2014/7/22:04:41:28 Path_Length: 148 2014/7/22:04:41:28 Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US 2014/7/22:04:41:28 Launch 2014/7/22:04:41:28 CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US_... /SN 900-31630700 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/7/22:04:41:28 Path_Length: 148 2014/7/22:04:41:28 Current Directory C:\Users\Luke\AppData\Local\Temp\_AI492B.tmp 2014/7/22:04:41:30 === Setup ended === 2014/7/22:04:41:28 === Setup started on SASHA by Luke === 2014/7/22:04:41:28 Path_Length: 148 2014/7/22:04:41:28 Current Directory C:\Users\Luke\AppData\Local\Temp\_AI492B.tmp 2014/7/22:04:41:28 Launch 2014/7/22:04:41:29 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/SETUP_x64... 2014/7/22:04:41:30 PageOpen LaunchDialog 2014/7/22:04:41:33 PageOpen LicenseDialog 2014/7/22:04:41:33 PageOpen ProductInfoDialog 2014/7/22:04:41:33 PageOpen ProductSelectionDialog2 2014/7/22:04:41:35 PageOpen FullProgressDialog 2014/7/22:04:41:36 Download Error Connection has expired. Please reconnect to site. VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US_... 2014/7/22:04:41:36 Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603 2014/7/22:04:41:37 PageOpen InstallCompleteDialog 2014/7/22:04:48:38 === Setup ended === 2014/7/22:04:50:53 === Setup started on SASHA by Luke === 2014/7/22:04:50:53 Path_Length: 148 2014/7/22:04:50:53 Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US 2014/7/22:04:50:53 Launch 2014/7/22:04:50:53 CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US_... /SN 900-31630700 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID 2014/7/22:04:50:53 Path_Length: 148 2014/7/22:04:50:53 Current Directory C:\Users\Luke\AppData\Local\Temp\_AIE787.tmp 2014/7/22:04:50:55 === Setup ended === 2014/7/22:04:50:54 === Setup started on SASHA by Luke === 2014/7/22:04:50:54 Path_Length: 148 2014/7/22:04:50:54 Current Directory C:\Users\Luke\AppData\Local\Temp\_AIE787.tmp 2014/7/22:04:50:54 Launch 2014/7/22:04:50:55 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/SETUP_x64... 2014/7/22:04:50:55 PageOpen LaunchDialog 2014/7/22:04:50:59 PageOpen LicenseDialog 2014/7/22:04:50:59 PageOpen ProductInfoDialog 2014/7/22:04:50:59 PageOpen ProductSelectionDialog2 2014/7/22:04:51:02 PageOpen FullProgressDialog 2014/7/22:04:51:03 Download Error Connection has expired. Please reconnect to site. VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US_... 2014/7/22:04:51:03 Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
I have removed PC and Username
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Or you can download the prereq program from Microsoft and preinstall it as well. Whatever works best for your situation.
I've tried that, I end up getting a
type Status report message /autodesk/SWDLDNET4/2015/3DSMAX/DLM/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R1_dlm.sfx.exe description The requested resource is not available.
, as for installing
the prereqs I'll give it a shot, Thanks!
