Installation & Licensing
Active Member
raul-herrera
Message 1 of 10 (2,710 Views)
Cannot install 3D Studio Max
2710 Views, 9 Replies
10-31-2011 10:06 AM
Message error:
My Machine use Windows 7 64 bit, evga classified sr-2, 8gb ram, nvidia fx3800, xeon x5680
2011/10/31:11:49:06 Ing Raul Herrera D GERENCIA === Setup started on GERENCIA by Ing Raul Herrera D ===
2011/10/31:11:49:06 Ing Raul Herrera D GERENCIA Launch
2011/10/31:11:49:14 Ing Raul Herrera D GERENCIA PageOpen LaunchDialog
2011/10/31:11:49:26 Ing Raul Herrera D GERENCIA PageOpen LicenseDialog
2011/10/31:11:49:31 Ing Raul Herrera D GERENCIA PageOpen ProductInfoDialog
2011/10/31:11:49:36 Ing Raul Herrera D GERENCIA PageOpen ProductSelectionDialog2
2011/10/31:11:49:54 Ing Raul Herrera D GERENCIA PageOpen FullProgressDialog
2011/10/31:11:49:55 Ing Raul Herrera D GERENCIA Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\INGRAU~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2011/10/31:11:50:11 Ing Raul Herrera D GERENCIA Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
Product Support
david.lau
Message 2 of 10 (2,687 Views)
Re: Cannot install 3D Studio Max
11-01-2011 06:37 AM in reply to: raul-herrera
Can you change registry limited to 'unlimited'?
http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-Civil-3D-Microsoft-C-libraries-Error-19...
David Lau
Active Member
raul-herrera
Message 3 of 10 (2,678 Views)
11-01-2011 04:41 PM in reply to: david.lau
My Pc have 2 folders in the Registry system  with similar name (controlSet001 and controlSet002) and both have the key RegistrySizeLimit exactly you mention.
I create a key named:RegistrySizeLimit into CurrentControlSet\Control  (see the image) the same way you said, but the problem persist.
I think the problem is: vcredist_x64.exe. I can't install it.  I have five C++ install in my pc.:
1- Microsoft Visual C++ 2005 ATL Update kb973923 - x64 8.0.50727.4053
2- Microsoft Visual C++ 2005 Redistributable
3- Microsoft Visual C++ 2005 Redistributable x64
4- Microsoft Visual C++ 2008 Redistributable x64 9.0.30729.4148
5- Microsoft Visual C++ 2008 Redistributable x86 9.0.30729.4148
Best Regards,
Raul
Active Member
raul-herrera
Message 4 of 10 (2,676 Views)
11-01-2011 04:44 PM in reply to: david.lau
I install windows service pack: Windows6.1-KB947821-v14-x64.msu but nothing
Active Member
raul-herrera
Message 5 of 10 (2,673 Views)
11-01-2011 05:13 PM in reply to: david.lau
If C++ can't install 3dstudio max neither
Active Member
raul-herrera
Message 6 of 10 (2,668 Views)
11-01-2011 05:48 PM in reply to: david.lau
2011/11/1:19:41:16 Ing Raul Herrera D GERENCIA PageOpen LicenseDialog
2011/11/1:19:44:55 Ing Raul Herrera D GERENCIA PageOpen ProductInfoDialog
2011/11/1:19:44:59 Ing Raul Herrera D GERENCIA PageOpen ProductSelectionDialog2
2011/11/1:19:45:07 Ing Raul Herrera D GERENCIA PageOpen FullProgressDialog
2011/11/1:19:45:08 Ing Raul Herrera D GERENCIA Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\INGRAU~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2011/11/1:19:45:22 Ing Raul Herrera D GERENCIA Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603
Product Support
byron.morales
Message 7 of 10 (2,632 Views)
11-10-2011 09:36 AM in reply to: raul-herrera
Hello Raul:
Please uninstall and re-install the VCREDIST packages. Usually, it works best to uninstall them in this order
2010 x86
2008x64
2008x86
2005x64
2005x86
Then reinstall in the opposite order:
2005 x86
2005 x64 etc.
You can locate the packages in the 3rdParty\x86 and 3rdParty/x64 VCREDIST folders in the install media or deployment.
Let us know if this resolves the problem you are encountering.
Byron Morales
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution.
Byron Morales
Product Support
byron.morales
Message 8 of 10 (2,596 Views)
11-15-2011 10:20 AM in reply to: byron.morales
Hello Raul:
I wanted to follow up with you to see if the suggestion I previously sent you resolved your issue?
Byron Morales
Byron Morales
New Member
lhepfner
Message 9 of 10 (1,225 Views)
01-22-2013 01:32 PM in reply to: raul-herrera
Sharing my experience: with error codes 1603, 1619. Partial log files below.
I am a student trying to install Revit Architecture and Civil 3D on a new installation of windows7 as the primary OS of two.
Civil 3D Problem - Pop up window during install  ".Net 4.0 is not installed..."
Civil 3D Fix          - In programs and features I selected uninstall/change for the:
                                     "Microsoft .NET Framework 4 Client Profile, and Extended."
                                     Then selected "Repair" for both of them.
                            - Also I completed several Microsof Updates after repairing the two.
                            - Then reinstalled Civil 3D and everything worked great, also uptaded Civil 3D
Revit Problem    - Failed to install C++ and everything else 2.5sec after selecting install
                                       Also pop up during install "Failed to find node://Blahblahblah... System error: -2147020584"
Revit Fix            - Went through files prevously suggested in this thread (3rdParty>x64 (and x84)>VCRedist)
                                      Maunally installed (or repair if available)
                          - When repairing C++ 2010 under x84 files
                                      Repair failed because "newer version of C++ 2010 exists."
                          - in Programs and Features I "Unenstalled" this version of C++
                                      tried again to "Repair" this C++ file under 3rdParty files and it worked. sucessfull install.
                          - Then reinstalled Revit and installation was sucessfull.
Partial Log Files:
Civil 3D error codes: 1603, 1619-
"Install AutoCAD Civil 3D 2012 Failed Installation aborted, Result=1603
 Rollback Microsoft Visual Basic Power Packs 3.0 Failed Failure is ignored, Result=1619
 Rollback SQL Server CE 3.5 x64 Succeeded
 Rollback SQL Server CE 3.5 x86 Succeeded
 Rollback Autodesk Content Service Succeeded
 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
 Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
 Rollback Autodesk Material Library 2012 Succeeded
 Rollback FaroSDK Succeeded
 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Revit error codes: 1603, 1619-
Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\landon7\AppData\Local\Temp\vcredist_x86_2005.log"" "
 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
 Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\landon7\AppData\Local\Temp\vcredist_x86_2010.log
 Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
TravisNave
Message 10 of 10 (1,220 Views)
01-22-2013 01:50 PM in reply to: lhepfner
Keep in mind on the log files, you do not have to worry about Failure Ignorederrors, nor the Rollback lines.  Those are not relevant to the error.  In your log, the failure is with the Install of the Visual C++ Redistributables.
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
In addition, rather that respond to a post that is over a year old, you should start a new one.
