Installation & Licensing
cannot give back borrowed licenses
10 REPLIES 10
Message 1 of 11
martin.stauch
671 Views, 10 Replies
I write this message again, because th first was in the wrong discussion Group
Problem:
We had borrowed licenses for 180 days, we gave them back.
Then we have created a opt file with MAX_BORROW_HOURS 64400AMECH_PP_F 72 and forgot to activate the "Force server shutdown" in the lmtools when we have stopped and started the server.
Now I have again borrowed licenses which are really not borrowed.
We have this problem for 4 Users. See file 03 after restart of server user ligangfr and three other user again here.txt
(ligangfr & sfaspaas & wistauma & wypilsmi)
What can I do?
10 REPLIES 10
Message 2 of 11
TravisNave
in reply to: martin.stauch
Welcome to the community.
Since the license server does not think they are borrowed, you have two choices:
1.  You can just wait for the client machines to expire
2.  You can manually remove the borrowed license from the registry.
To remove it, simply clear the following registry key:
HKEY_CURRENT_USER\Software\FLEXlm License Manager\Borrow
For more information, see this KB link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10305068&linkID=9240617
Good Luck!
Autodesk Forums:
Message 3 of 11
martin.stauch
in reply to: TravisNave
Hello!
It didn' worked.
when I borrow the license my user "wistauma" appears 2 times with different
linger time.
The old and wrong one: wistauma WI025123NB WI025123NB (v1.000)
(WYACLICWN/27001 601), start Tue 7/30 11:23 (linger: 1847640)
The new one: wistauma WI025123NB WI025123NB (v1.0) (WYACLICWN/27001 1810),
start Tue 7/30 16:57 (linger: 198060)
"64400AMECH_PP_F" v1.000, vendor: adskflex
floating license
WYLEICAN WY024069NB WY024069NB (v1.000) (WYACLICWN/27001 1908), start
Tue 7/30 16:50
frmitiga FR600160PC FR600160PC (v1.000) (WYACLICWN/27001 5307), start
Tue 7/30 15:11
hhdinhin HH700103PC HH700103PC (v1.000) (WYACLICWN/27001 2108), start
Tue 7/30 15:47
hhstanol HH700101PC HH700101PC (v1.000) (WYACLICWN/27001 3712), start
Tue 7/30 16:31
ligangfr LI024906NB LI024906NB (v1.000) (WYACLICWN/27001 301), start
Tue 7/30 11:23 (linger: 15502260)
lokawaan LO540109PC LO540109PC (v1.000) (WYACLICWN/27001 2408), start
Tue 7/30 16:32
morizeta MO520210PC MO520210PC (v1.000) (WYACLICWN/27001 4908), start
Tue 7/30 13:45
sbgrubje SB024803PC SB024803PC (v1.000) (WYACLICWN/27001 6306), start
Tue 7/30 16:41
sfaspaas SF021293NB SF021293NB (v1.000) (WYACLICWN/27001 201), start
Tue 7/30 11:23 (linger: 15486300)
stkrafru ST024494NB ST024494NB (v1.000) (WYACLICWN/27001 4509), start
Tue 7/30 14:32 (linger: 120360)
wistauma WI025123NB WI025123NB (v1.000) (WYACLICWN/27001 601), start
wypilsmi WY025240PC WY025240PC (v1.000) (WYACLICWN/27001 101), start
Tue 7/30 11:23 (linger: 15520260)
wywallmi WY024047PC WY024047PC (v1.000) (WYACLICWN/27001 501), start
Tue 7/30 11:23 (linger: 1939500)
Users of 85733AMECH_PP_2012_0F: (Total of 39 licenses issued; Total of 10
licenses in use)
"85733AMECH_PP_2012_0F" v1.000, vendor: adskflex
floating license
WYLEICAN WY024069NB WY024069NB (v1.0) (WYACLICWN/27001 2809), start Tue
7/30 16:50
frmitiga FR600160PC FR600160PC (v1.0) (WYACLICWN/27001 5602), start Tue
7/30 15:11
hhdinhin HH700103PC HH700103PC (v1.0) (WYACLICWN/27001 3305), start Tue
7/30 15:47
hhstanol HH700101PC HH700101PC (v1.0) (WYACLICWN/27001 1307), start Tue
7/30 16:31
lokawaan LO540109PC LO540109PC (v1.0) (WYACLICWN/27001 1507), start Tue
7/30 16:32
morizeta MO520210PC MO520210PC (v1.0) (WYACLICWN/27001 3504), start Tue
7/30 13:45
sbgrubje SB024803PC SB024803PC (v1.0) (WYACLICWN/27001 1612), start Tue
7/30 16:41
stkrafru ST024494NB ST024494NB (v1.0) (WYACLICWN/27001 1408), start Tue
wistauma WI025123NB WI025123NB (v1.0) (WYACLICWN/27001 1810), start Tue
wywallmi WY024047PC WY024047PC (v1.0) (WYACLICWN/27001 401), start Tue
And when I give the license back the old one stays,... wistauma WI025123NB
WI025123NB (v1.000) (WYACLICWN/27001 701), start Tue 7/30 11:23 (linger:
1847640)
Users of 64400AMECH_PP_F: (Total of 39 licenses issued; Total of 12
licenses in use)
floating license
Tue 7/30 16:50
Tue 7/30 15:11
Tue 7/30 15:47
lokawaan LO540109PC LO540109PC (v1.000) (WYACLICWN/27001 2409), start
Tue 7/30 16:59
Tue 7/30 13:45
Tue 7/30 16:41
wistauma WI025123NB WI025123NB (v1.000) (WYACLICWN/27001 701), start
Users of 85733AMECH_PP_2012_0F: (Total of 39 licenses issued; Total of 9
licenses in use)
floating license
7/30 16:50
7/30 15:11
7/30 15:47
lokawaan LO540109PC LO540109PC (v1.0) (WYACLICWN/27001 1508), start Tue
7/30 16:59
7/30 13:45
7/30 16:41
wistauma WI025123NB WI025123NB (v1.0) (WYACLICWN/27001 1811), start Tue
7/30 16:59
Very bad,....
Mit freundlichen Gr??en / Kind regards
Martin Stauch
Applicationmanager CAD/Presenter - IT Salessupport
BENE AG A-1010 Wien Neutorgasse 4-8
Telefon +43-1-53426-1310 Fax +43-1-53426-991310 Mobil +43-676-81511310
mailto:martin.stauch@bene.com www.bene.com
Firma: BENE AG Rechtsform: Aktiengesellschaft Sitz: Waidhofen/Ybbs
Firmenbuchnummer: 89102 h Firmenbuchgericht: Landesgericht St. P?lten
Message 4 of 11
TravisNave
Return the new borrowed license.  Stop the server.  Remove the options file temporarily.  Start the server.  Reborrow.  Verify, then return.  Then put back the options file.  See if that works.
Autodesk Forums:
Message 5 of 11
martin.stauch
Hello!
It didn't worked.
I have tried it with my user wistauma and the license stays,..
And now, after server restart, ALL - the wrong (4) and correct (2) borrowed
licenses start again with today!
That is very bad,...
What can I do now?
look:
Users of 64400AMECH_PP_F: (Total of 39 licenses issued; Total of 15
licenses in use)
floating license
bkpanalo BK024806PC BK024806PC (v1.000) (WYACLICWN/27001 2801), start
Wed 7/31 8:59
brhatizu BR024958PC BR024958PC (v1.000) (WYACLICWN/27001 1401), start
Wed 7/31 8:58
hhmengme HH024822PC HH024822PC (v1.000) (WYACLICWN/27001 2401), start
Wed 7/31 8:58
klwoltma KL024306PC KL024306PC (v1.000) (WYACLICWN/27001 1002), start
Wed 7/31 9:03
Wed 7/31 8:57 (linger: 15502260)
sbscholu SB024478PC SB024478PC (v1.000) (WYACLICWN/27001 1601), start
Wed 7/31 8:58
Wed 7/31 8:57 (linger: 15486300)
simuslmu SI024009NB SI024009NB (v1.000) (WYACLICWN/27001 1201), start
Wed 7/31 8:58
stkrafru ST024494NB ST024494NB (v1.000) (WYACLICWN/27001 901), start
Wed 7/31 8:57 (linger: 120360)
Wed 7/31 8:57 (linger: 1847640)
wyhenima WY024059PC WY024059PC (v1.000) (WYACLICWN/27001 2001), start
Wed 7/31 8:58
Wed 7/31 8:57 (linger: 15520260)
wyriglth WY024048PC WY024048PC (v1.000) (WYACLICWN/27001 2204), start
Wed 7/31 9:06
wystocso WY020858PC WY020858PC (v1.000) (WYACLICWN/27001 2601), start
Wed 7/31 8:58
Wed 7/31 8:57 (linger: 1939500)
Users of 85733AMECH_PP_2012_0F: (Total of 39 licenses issued; Total of 12
licenses in use)
floating license
bkpanalo BK024806PC BK024806PC (v1.0) (WYACLICWN/27001 2901), start Wed
7/31 8:59
brhatizu BR024958PC BR024958PC (v1.0) (WYACLICWN/27001 1501), start Wed
7/31 8:58
hhmengme HH024822PC HH024822PC (v1.0) (WYACLICWN/27001 2501), start Wed
7/31 8:58
klwoltma KL024306PC KL024306PC (v1.0) (WYACLICWN/27001 1102), start Wed
7/31 9:03
sbscholu SB024478PC SB024478PC (v1.0) (WYACLICWN/27001 1701), start Wed
7/31 8:58
simuslmu SI024009NB SI024009NB (v1.0) (WYACLICWN/27001 1301), start Wed
7/31 8:58
stkrafru ST024494NB ST024494NB (v1.0) (WYACLICWN/27001 801), start Wed
wistauma WI025123NB WI025123NB (v1.0) (WYACLICWN/27001 2305), start Wed
7/31 9:06
wyhenima WY024059PC WY024059PC (v1.0) (WYACLICWN/27001 2101), start Wed
7/31 8:58
wyriglth WY024048PC WY024048PC (v1.0) (WYACLICWN/27001 3301), start Wed
7/31 9:06
wystocso WY020858PC WY020858PC (v1.0) (WYACLICWN/27001 2701), start Wed
7/31 8:58
wywallmi WY024047PC WY024047PC (v1.0) (WYACLICWN/27001 401), start Wed
Martin Stauch
Message 6 of 11
martin.stauch
Hello again!
Here is also another protocoll:
There you see, that wen I shutdown the server the borrowed licenses of the wrong users like ligangfr end in 147841 minutes (102,6 days)
Then after restart the user gets and borrows a licence for 179,4 days, but he isn't in acad.
This happens to all 4 users !!!
log protocoll:
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" ligangfr@LI024906NB
Server status:
ligangfr LI024906NB LI024906NB (v1.000) (WYACLICWN/27001 301), start Wed 7/31 9:13 (linger: 15502260)
log protocoll:
8:56:56 (adskflex) BORROWED: 64400AMECH_PP_F wypilsmi/WY025240PC/WY025240PC exp: 35461 minutes
8:56:56 (adskflex) BORROWED: 64400AMECH_PP_F sfaspaas/SF021293NB/SF021293NB exp: 38281 minutes
8:56:56 (adskflex) BORROWED: 64400AMECH_PP_F ligangfr/LI024906NB/LI024906NB exp: 147841 minutes
8:56:56 (adskflex) BORROWED: 64400AMECH_PP_F wywallmi/WY024047PC/WY024047PC exp: 901 minutes
8:56:56 (adskflex) BORROWED: 64400AMECH_PP_F stkrafru/ST024494NB/ST024494NB exp: 901 minutes
8:56:56 (adskflex) BORROWED: 85733AMECH_PP_2012_0F wywallmi/WY024047PC/WY024047PC exp: 901 minutes
8:56:56 (adskflex) BORROWED: 85733AMECH_PP_2012_0F stkrafru/ST024494NB/ST024494NB exp: 901 minutes
8:56:56 (adskflex) Shutdown requested from SYSTEM@WYACLICWN IP=172.16.33.69
8:56:56 (adskflex) daemon shutdown requested - shutting down
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wypilsmi@WY025240PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" sfaspaas@SF021293NB  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" ligangfr@LI024906NB  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wywallmi@WY024047PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wistauma@WI025123NB  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" stkrafru@ST024494NB  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wystocso@WY020858PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" alfedool@AL490018PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wybachch@WY024256NB  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" bkpanalo@BK024806PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wyriglth@WY024048PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" brhatizu@BR024958PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" simuslmu@SI024009NB  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" wyhenima@WY024059PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" sbscholu@SB024478PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "64400AMECH_PP_F" duamorma@DU530020PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "59200AMECH_PP_2009_0F" wytascbr@wy021783pc  (SHUTDOWN)
8:56:56 (adskflex) IN: "59200AMECH_PP_2009_0F" wydreith@wy020286pc  (SHUTDOWN)
8:56:56 (adskflex) IN: "59200AMECH_PP_2009_0F" wyriegma@wy021781pc  (SHUTDOWN)
8:56:56 (adskflex) IN: "59200AMECH_PP_2009_0F" wyreitco@wy024610nb  (SHUTDOWN)
8:56:56 (adskflex) IN: "59200AMECH_PP_2009_0F" wykatzmi@wy020333pc  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" wywallmi@WY024047PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" stkrafru@ST024494NB  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" wystocso@WY020858PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" alfedool@AL490018PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" wybachch@WY024256NB  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" bkpanalo@BK024806PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" wyriglth@WY024048PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" brhatizu@BR024958PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" simuslmu@SI024009NB  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" wyhenima@WY024059PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" sbscholu@SB024478PC  (SHUTDOWN)
8:56:56 (adskflex) IN: "85733AMECH_PP_2012_0F" duamorma@DU530020PC  (SHUTDOWN)
9:13:49 (adskflex) Server started on WYACLICWN for:
9:13:49 (adskflex) 64400AMECH_PP_F (consisting of: 59200AMECH_PP_2009_0F
9:13:49 (adskflex) 85545AMECH_PP_2011_0F 71800AMECH_PP_2010_0F 85733AMECH_PP_2012_0F)
9:13:49 (adskflex) 85814PDSP_F (consisting of: 59200AMECH_PP_2009_0F
9:13:49 (adskflex) 85795PDSP_2012_0F 85573INVBUN_2011_0F 85607SHOWCASE_2011_0F
9:13:49 (adskflex) 85615ALSK_2011_0F 85580MBXPRO_2011_0F 85545AMECH_PP_2011_0F
9:13:49 (adskflex) 85503MAXDES_2011_0F 85579INVNTOR_2011_0F 70400INVBUN_2010_0F
9:13:49 (adskflex) 83900MBXPRO_2010_0F 71800AMECH_PP_2010_0F 70000MAXDES_2010_0F
9:13:49 (adskflex) 85577INVNTOR_2010_0F 59300INVBUN_2009_0F 612003DSMAX_2009_0F
9:13:49 (adskflex) 70200MBXPRO_2009_0F) 59200AMECH_PP_2009_0F PLIST
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" wypilsmi@WY025240PC
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" sfaspaas@SF021293NB
9:13:49 (adskflex) OUT: "85733AMECH_PP_2012_0F" wywallmi@WY024047PC
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" wywallmi@WY024047PC
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" wistauma@WI025123NB
9:13:49 (adskflex) OUT: "85733AMECH_PP_2012_0F" stkrafru@ST024494NB
9:13:49 (adskflex) OUT: "64400AMECH_PP_F" stkrafru@ST024494NB
9:14:24 (adskflex) TCP_NODELAY NOT enabled
9:14:24 (adskflex) OUT: "64400AMECH_PP_F" mokulbok@MO520221PC
9:14:24 (adskflex) OUT: "85733AMECH_PP_2012_0F" mokulbok@MO520221PC
9:14:33 (adskflex) OUT: "64400AMECH_PP_F" wyriglth@WY024048PC
9:14:33 (adskflex) OUT: "85733AMECH_PP_2012_0F" wyriglth@WY024048PC
9:14:39 (adskflex) OUT: "59200AMECH_PP_2009_0F" wyhoenan@wy021768pc
9:14:41 (adskflex) OUT: "64400AMECH_PP_F" hhdinhin@HH700103PC
9:14:41 (adskflex) OUT: "85733AMECH_PP_2012_0F" hhdinhin@HH700103PC
9:14:43 (adskflex) OUT: "59200AMECH_PP_2009_0F" wyschrju@wy021777pc
9:14:52 (adskflex) OUT: "64400AMECH_PP_F" wystocso@WY020858PC
9:14:52 (adskflex) OUT: "85733AMECH_PP_2012_0F" wystocso@WY020858PC
9:14:57 (adskflex) OUT: "59200AMECH_PP_2009_0F" wykatzmi@wy020333pc
9:15:03 (adskflex) OUT: "64400AMECH_PP_F" brhatizu@BR024958PC
9:15:03 (adskflex) OUT: "85733AMECH_PP_2012_0F" brhatizu@BR024958PC
9:15:04 (adskflex) OUT: "64400AMECH_PP_F" simuslmu@SI024009NB
9:15:04 (adskflex) OUT: "85733AMECH_PP_2012_0F" simuslmu@SI024009NB
9:15:12 (adskflex) OUT: "59200AMECH_PP_2009_0F" wyreitco@wy024610nb
9:15:15 (adskflex) OUT: "64400AMECH_PP_F" wistauma@WI025123NB
9:15:15 (adskflex) OUT: "85733AMECH_PP_2012_0F" wistauma@WI025123NB
9:15:17 (adskflex) OUT: "59200AMECH_PP_2009_0F" wyriegma@wy021781pc
9:15:27 (adskflex) OUT: "59200AMECH_PP_2009_0F" wydreith@wy020286pc
9:15:29 (adskflex) OUT: "59200AMECH_PP_2009_0F" wytascbr@wy021783pc
9:15:35 (adskflex) OUT: "64400AMECH_PP_F" klwoltma@KL024306PC
9:15:35 (adskflex) OUT: "85733AMECH_PP_2012_0F" klwoltma@KL024306PC
9:15:53 (adskflex) OUT: "64400AMECH_PP_F" wylaenno@WY025050PC
9:15:53 (adskflex) OUT: "85733AMECH_PP_2012_0F" wylaenno@WY025050PC
9:16:06 (adskflex) OUT: "64400AMECH_PP_F" bkpanalo@BK024806PC
9:16:06 (adskflex) OUT: "85733AMECH_PP_2012_0F" bkpanalo@BK024806PC
9:16:30 (adskflex) OUT: "59200AMECH_PP_2009_0F" wypoecml@wy470034pc
9:16:46 (adskflex) OUT: "64400AMECH_PP_F" sbscholu@SB024478PC
9:16:46 (adskflex) OUT: "85733AMECH_PP_2012_0F" sbscholu@SB024478PC
9:17:54 (adskflex) IN: "85733AMECH_PP_2012_0F" sbscholu@SB024478PC
9:17:54 (adskflex) IN: "64400AMECH_PP_F" sbscholu@SB024478PC
9:18:42 (adskflex) OUT: "59200AMECH_PP_2009_0F" wyschrju@wy021777pc
9:19:09 (adskflex) OUT: "64400AMECH_PP_F" sbscholu@SB024478PC
9:19:09 (adskflex) OUT: "85733AMECH_PP_2012_0F" sbscholu@SB024478PC
9:19:49 (adskflex) IN: "85733AMECH_PP_2012_0F" sbscholu@SB024478PC
9:19:49 (adskflex) IN: "64400AMECH_PP_F" sbscholu@SB024478PC
9:20:10 (adskflex) IN: "59200AMECH_PP_2009_0F" wyreitco@wy024610nb
Server status:
Users of 64400AMECH_PP_F:  (Total of 39 licenses issued;  Total of 19 licenses in use)
  floating license
    bkpanalo BK024806PC BK024806PC (v1.000) (WYACLICWN/27001 3601), start Wed 7/31 9:16
    brhatizu BR024958PC BR024958PC (v1.000) (WYACLICWN/27001 2201), start Wed 7/31 9:15
    hhdinhin HH700103PC HH700103PC (v1.000) (WYACLICWN/27001 1601), start Wed 7/31 9:14
    klwoltma KL024306PC KL024306PC (v1.000) (WYACLICWN/27001 3201), start Wed 7/31 9:15
    mogoncal MO520207PC MO520207PC (v1.000) (WYACLICWN/27001 4201), start Wed 7/31 9:27
    mokulbok MO520221PC MO520221PC (v1.000) (WYACLICWN/27001 1101), start Wed 7/31 9:14
    sfaspaas SF021293NB SF021293NB (v1.000) (WYACLICWN/27001 201), start Wed 7/31 9:13 (linger: 15486300)
    simuslmu SI024009NB SI024009NB (v1.000) (WYACLICWN/27001 2401), start Wed 7/31 9:15
    stkrafru ST024494NB ST024494NB (v1.000) (WYACLICWN/27001 901), start Wed 7/31 9:13 (linger: 120360)
    wistauma WI025123NB WI025123NB (v1.000) (WYACLICWN/27001 601), start Wed 7/31 9:13 (linger: 1847640)
    wyfieska WY024728NB WY024728NB (v1.000) (WYACLICWN/27001 4701), start Wed 7/31 9:30
    wykrenma WY021784PC WY021784PC (v1.000) (WYACLICWN/27001 1502), start Wed 7/31 9:27
    wylaenno WY025050PC WY025050PC (v1.000) (WYACLICWN/27001 3401), start Wed 7/31 9:15
    wymurawo WY021850NB WY021850NB (v1.000) (WYACLICWN/27001 4004), start Wed 7/31 9:28
    wypilsmi WY025240PC WY025240PC (v1.000) (WYACLICWN/27001 101), start Wed 7/31 9:13 (linger: 15520260)
    wyriglth WY024048PC WY024048PC (v1.000) (WYACLICWN/27001 1301), start Wed 7/31 9:14
    wystocso WY020858PC WY020858PC (v1.000) (WYACLICWN/27001 1901), start Wed 7/31 9:14
    wywallmi WY024047PC WY024047PC (v1.000) (WYACLICWN/27001 501), start Wed 7/31 9:13 (linger: 1939500)
Users of 85733AMECH_PP_2012_0F:  (Total of 39 licenses issued;  Total of 16 licenses in use)
  floating license
    bkpanalo BK024806PC BK024806PC (v1.0) (WYACLICWN/27001 3701), start Wed 7/31 9:16
    brhatizu BR024958PC BR024958PC (v1.0) (WYACLICWN/27001 2301), start Wed 7/31 9:15
    hhdinhin HH700103PC HH700103PC (v1.0) (WYACLICWN/27001 1701), start Wed 7/31 9:14
    klwoltma KL024306PC KL024306PC (v1.0) (WYACLICWN/27001 3301), start Wed 7/31 9:15
    mogoncal MO520207PC MO520207PC (v1.0) (WYACLICWN/27001 4301), start Wed 7/31 9:27
    mokulbok MO520221PC MO520221PC (v1.0) (WYACLICWN/27001 1201), start Wed 7/31 9:14
    simuslmu SI024009NB SI024009NB (v1.0) (WYACLICWN/27001 2501), start Wed 7/31 9:15
    stkrafru ST024494NB ST024494NB (v1.0) (WYACLICWN/27001 801), start Wed 7/31 9:13 (linger: 120360)
    wistauma WI025123NB WI025123NB (v1.0) (WYACLICWN/27001 2801), start Wed 7/31 9:15
    wyfieska WY024728NB WY024728NB (v1.0) (WYACLICWN/27001 4801), start Wed 7/31 9:30
    wykrenma WY021784PC WY021784PC (v1.0) (WYACLICWN/27001 4102), start Wed 7/31 9:27
    wylaenno WY025050PC WY025050PC (v1.0) (WYACLICWN/27001 3501), start Wed 7/31 9:15
    wymurawo WY021850NB WY021850NB (v1.0) (WYACLICWN/27001 4601), start Wed 7/31 9:28
    wyriglth WY024048PC WY024048PC (v1.0) (WYACLICWN/27001 1401), start Wed 7/31 9:14
    wystocso WY020858PC WY020858PC (v1.0) (WYACLICWN/27001 2001), start Wed 7/31 9:14
    wywallmi WY024047PC WY024047PC (v1.0) (WYACLICWN/27001 401), start Wed 7/31 9:13 (linger: 1939500)
Mit freundlichen Grüßen / Kind regards
Martin Stauch
Firmenbuchnummer: 89102 h  Firmenbuchgericht: Landesgericht St. Pölten
Message 7 of 11
TravisNave
Do you have any other licenses in your license file, or is this the only product?
Autodesk Forums:
Message 8 of 11
martin.stauch
Dear Travis!
We have also other products, should I upload our lic file here for you?
Best regards
Martin Stauch
Message 9 of 11
TravisNave
You can copy it into a PM to me if you wish.  Since you have multiple products, I think I have a clever way for you to clear your stuck licenses.
Autodesk Forums:
Message 10 of 11
jobermeyer1960
Travis and Martin,
This EXACT thing happened to me, if I am understanding correctly.  Every time I restart my license server, THREE of our users get assigned borrowed licenses lasting about 180 days.  This happens regardless of whether these users are even working in AutoCAD at the time of the server restart.  It also happens even though my options file limits license borrowing to 16 days.  Also, the borrow expiration day then as reported by the server is different than the borrow expiration date as reported by the AutoCAD installation on the individual PC.
I hope the "clever way" you mentioned, Travis, would apply to my case.
Please advise.
Thank you.
Jamie
Message 11 of 11
TravisNave
in reply to: jobermeyer1960
If your licenses are being borrowed for longer than your options file allows, then you probably have a typo in your options file.
Autodesk Forums:
Administrator Productivity
