Installation & Licensing
Active Member
orenofer
Message 11 of 15 (478 Views)
Re: cannot find network license manager
06-26-2013 12:51 AM in reply to: Darin.Green
I couldn't find such key.
I turned off the firewall -- it remains the same, no difference with or without the firewall.
Active Member
orenofer
Message 12 of 15 (475 Views)
06-26-2013 01:01 AM in reply to: orenofer
i did find a key as you described under
HKEY_LOCAL_MACHINE/SOFTWARE/FLEXlm License Manager/autodesk
but changing as you mentioned didn't help either: it wasn't able to start the license server (when tested with LMTOOLS->Server Status->Perform Status Enquiry)
TravisNave
Message 13 of 15 (464 Views)
06-26-2013 09:55 AM in reply to: orenofer
Please PING the server hostname (not IP) from a CMD prompt and post the results.
Active Member
orenofer
Message 14 of 15 (453 Views)
06-26-2013 10:30 PM in reply to: TravisNave
here attached.
TravisNave
Message 15 of 15 (427 Views)
06-28-2013 07:45 AM in reply to: orenofer
Your issue is IPv6 related.  See my fix for this.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
