Installation & Licensing
cannot find network license manager
14 REPLIES 14
Message 1 of 15
orenofer
3545 Views, 14 Replies
HI,
I'm trying to setup inventor pro 2014 with a network license manager.
I've followed the instructions and LMTOOLS acknowledges that the server is UP.
I've down this twice: once on a dedicated network license manager and one on my own computer where i have installed the inventor. In either cases, I receive the same problem:
When i start inventor it prompts me to either a license file or the license manager computer host name. Neither work: After several times, of inputing the host name, or giving the license file, I receive "A valid license could not be obtained by the network license manager" error [-1.359.2]
I tried opening port 2080 on the windows firewall. no change.
Please advice.
14 REPLIES 14
Message 2 of 15
DarrenP
in reply to: orenofer
can you ping the license server by hostname?
DarrenP
Message 3 of 15
DarrenP
in reply to: DarrenP
The FLEXlm® based version uses the following ports:
TCP ports 2080 (for the adskflex vendor daemon)
TCP ports 27000 to 27009 (for the lmgrd master daemon)
you also have to allow these ports through the firewall
DarrenP
Message 4 of 15
orenofer
yes. no problem there.
Message 5 of 15
DarrenP
Please advice.
what if you use the Ip address instead?
then does inventor find a license
DarrenP
Message 6 of 15
orenofer
I've opened these ports. no change ;-( .
"A valid license could not be obtained by the network license manager." Error [-15.570.0]
Message 7 of 15
orenofer
nop. by using directly the IP doesn't help either. as well as 127.0.0.1 , localhost ..
Message 8 of 15
Darin.Green
Can you post the log file for the license manager?
If this information was helpful, please consider using the Accept Solution
Message 9 of 15
orenofer
in reply to: Darin.Green
Here attached.
Message 10 of 15
Darin.Green
Is the License Manager and Inventor installed on the same machine? If so, try to completely disable the firewall and check the following registry key:
HKEY_CURRENT_USER\Software\FLEXlm License Manager
There should be a file named "ADSKFLEX_LICENSE_FILE" with a long string to the licpath.lic file.
Clear the value field and enter "@servername;@server IP address" <-- replace the text after each @ symbol with the correct information then try to start the application.
Message 11 of 15
orenofer
I couldn't find such key.
I turned off the firewall -- it remains the same, no difference with or without the firewall.
Message 12 of 15
orenofer
i did find a key as you described under
HKEY_LOCAL_MACHINE/SOFTWARE/FLEXlm License Manager/autodesk
but changing as you mentioned didn't help either: it wasn't able to start the license server (when tested with LMTOOLS->Server Status->Perform Status Enquiry)
Message 13 of 15
TravisNave
Please PING the server hostname (not IP) from a CMD prompt and post the results.
Autodesk Forums:
Message 14 of 15
orenofer
in reply to: TravisNave
here attached.
Message 15 of 15
TravisNave
Your issue is IPv6 related.  See my fix for this.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Autodesk Forums:
Administrator Productivity
