Have tried without success to export licence using LTU to install on a new laptop. Error message keeps saying serial number invalid (40). The product key / serial numbers are correct. Still have original box with Autocad USB. Have installed software on new laptop but LTU will not work on that machine. Have send emails for help to Autodesk over last 3 days. No response. Need help as workload building up. Any help gratefully received
Solved by johnmcgowan18. Go to Solution.
Welcome to the community..
Although you have given us a clear picture that the LTU is failing you but what Autodesk Product/Version is that you are trying to transfer?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Forget the LTU and just install and activate as needed.
If that fails, contact your reseller and/or submit a Support Request, you can do that here. You can also schedule a time for Autodesk Support to call you
Thanks for the information..
Is this suite on an active maintenance subscription? If so then you are not entitled to transfer this version anymore because if you have an active maintenance subscription then you can only use the current released version (2017) and 3 legacy versions.
If none of that is true above.. Did you have a maintenance subscription at one time for this suite and you went off of it? IF so then you are only entitled to use the version that was released at the time you elected not to renew your subscription.
If that is still not true... Then do what @rkmcswain just indicated... Just install and activate on the new machine.
Mark Lancaster
A couple of things (clarification) per your reply..
Scheduling a call with Autodesk is only permitted if the end user has Adv or Enterprise Support from Autodesk. This is a paid support and is needed for each application they own. However it is included free of charge if they have any of the LT products. But it can only be used for LT products and not a Building Design Suite.
Logging a support case through their Autodesk Account is only possible if that individual is the contract manager or software coordinator of their subscription. Or they have been assigned that benefit or capability to their named account.
Mark Lancaster
Thanks Mark
I no longer have an active maintenance subscription. So the first two suggestions are not available.
I have installed the software on the new laptop which was fine but i cannot see where i can activate to product. I keep getting the View Mode only.
If you did have a maintenance subscription for this suite and you didn't renew it.. When did that occur? Because as I stated before if you did have a subscription on this suite and you didn't elect to continue with it then you are only entitled to use the released version of the suite at the time your subscription elapsed. Meaning you could be in a non-compliance situation and you could be fine..
Mark Lancaster
I fully understand that we are not always privy in knowing everything at the OP end.
Sorry if my reply came across the wrong way.. It was merely meant as an addition to your posting but not wording in that fashion. Anyhow I was assuming you would get back "well I don't see that" and thus it would lead to more replies..
Mark Lancaster
Thanks guys appreciate the help
Have tried clicking on the submit a Support Request, you can do that here. but this gave me an error page. Clicked schedule a time for Autodesk Support to call you but this sent me somewhere i have been been before. Tried to schedule a support call 3 days ago. Had an acknowledgement email but nothing else.
Thought the hard bit was cloning a machine with several operating systems. Never considered the licence being an issue. How wrong i was
There's nothing you can do to get that previous activation onto a different machine. Technically, it should've been removed when subscription was dropped. That being the case, you'll need to uninstall and install the latest version you were entitled to when your subscription ended.
For example, if you're using if you're trying to install 2012, and your subscription ended while 2016 was still the latest, then you'll need to install and use 2016 because that 2012 serial number is no longer valid.
If you're still on subscription, then the serial number would still be invalid because its not within the current (2017) and back 3 versions to 2014. Again, you'll need to upgrade the software to a supported version or request previous use through your reseller.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Darin .... Being very stupid ... i have installed 2012 software on new laptop .... how do i update it
You'll need to uninstall it, then install the version that you own.
Darin Green
Thanks to all for your input ... will try to uninstall and install again.
Will post a result ... if i get one
Unfortunately..... having uninstalled everything and then reinstalled everything ..... i am still in the same position.
Cannot export the licence i thought i had paid for ... and unable to activate the licence on a new laptop. No response from customer support ...
Thanks to all that tried to help .... much appreciated
Attached ... one very expensive usb stick ... maybe i can sell it on Ebay .... thanks Autodesk .... you really know how to make life difficult !!!!!
