Installation & Licensing
Cannot activate Maya LT 2015 on OSX
3 REPLIES 3
gsabella
909 Views, 3 Replies
Hi, I just purchased a subscription license for Maya LT 2015. I am trying to activate it on my Mac (running OSX 10.9.4), but I get an "Invalid Serial Number" error message. I notice that when I try to enter my serial number into the text fields, the field for the second (8-digit) portion of the serial number only lets me enter 7 digits. It always cuts one out as soon as I finish entering text, and I believe that's what's causing the issue. There is another thread describing the exact same problem (and it is, of course, completely unanswered):
http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-Maya-2015-invalid-Serial-Number/td-p/5...
How can I get around this? I have a few more days of trial time left but obviously that won't last forever.
3 REPLIES 3
gsabella
in reply to: gsabella
Found a way around the problem. Downloaded the installer again and re-installed Maya LT. The installer has its own "I have a license key" page, which works correctly and accepted my key no problem. After entering it that way, Maya proceeded to verify the key and let me sign in automatically. Got activated no problem at that point.
To reiterate, the "Continue your trial or activate" window for Maya LT 2015 is still broken on Mac OSX (I'm on 10.9.4). But it is possible to get around it by entering your license info at installation.
Hopefully this helps someone out who might have the same issue.
jeffrey.sin
Thanks for the update gsabella. This has been noted, we will look into resolving this issuse. In the meantime, you are correct that you can just enter the serial number during the installation to activate the license instead.
Jeffrey Sin
Autodesk Customer Support
17watsoeth
i entered it in installation, and it still will not work...? btw I am using student license.
Administrator Productivity
