I currently have the Building Design Suite 2014, but we need to also from time to time go back to AutoCAD 2007, as we had a customized plug in toolbar which only works for that release.
The AutoCAD 2007 (from the AutoDesk Building Suite) will not run on our new 64 bit systems.
Anyone know if this is possible?
Thank you!
its a compatibility issue with the OS its not with it being 64 bit
your trying to run it on a OS that is not compatibile with 2007 for ex: Win 7
there are many solutions on getting older software to run on newer OSes
1 of them being using a 3rd party software called Longbow
what OS are you trying to run it on?
DarrenP
Darren,
Thanks for getting back with me.
We have just upgraded to Windows 7 - 64-Bit Professional with Service pack 1.
Mostly this upgrade is so we can do 3D AutoCAD, and 3DS Max, which was not supported on 32-bit systems.
My only other alternative, is to re-create the CUI for the new 2014 version.
Thanks!
