Hallo
I have unistalled autocad 2014 because of problems with a plugin. When i try to reinstall, it says that autocad i alredy installed. I have deleted all file and registry keys but it still show the same message. I have a student license. I have an exam in few days and i dont know what to do
thanks
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems, carefully consider using the Microsoft Installer Clean Up Utility at your own risk. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Good Luck!
i have done everything you wrote. the install-unistall utility doesen't work http://imgur.com/WourfuZ
if i use the utility it asks for, it can't find the problem
I managed to install autocad 2015 but activation code for student doesn't work ( 2014 version ).
the program recognizes the serial number but not the product key. how can i fix it or can i get a new one?
thanks in advance
It's probably 001G1. Make sure you type it and not copy/paste it.
Good Luck!
