Have installed/uninstalled Revit 2014 (student) multiple times using the different download options, installs successfully but unable to open it, occasionally will manage to get splash screen , but will display "Revit 2014 has stopped working" message seconds later.
Have tried changing display settings/graphics card is up to date/using a different user/running as administrator/using compatibility mode, and still not working.
specs:
OS: Windows 8.1
TOSHIBA Satellite Notebook
Intel (R) Core (TM) i5-3317U CPU @ 1.70GHz 1.70 GHz
4GB Ram
64-bit OS, x64 based processor
Intel HD 4000 Graphics Card
Please help!!!
Hello. Delete your ADSKFLEX TSF.data file and try again.
Windows XP:
Documents and Settings\All Users\Application Data\FLEXnet
Vista/Windows 7:
C:\ProgramData\FLEXnet
If this still does not help, look in your Windows Event Viewer. Do you have any failing modules? If you have any LMU.exe failing modules, you could have a conflict with a Windows Update.
Reboot and start program. After you activate, you can let the windows updates reinstall.
Thank you for taking part in our community!
Tried all of the steps you listed , apart from deleting KB2962872 as I did not have it, but still not working, no change at all.
