Installation & Licensing
Can't open a saved DWG file in sketchbook Designer. "failed to send ...
3 REPLIES 3
washout13
775 Views, 3 Replies
I am using an edu Version of Sketchbook Designer 2014 on Win 8.
Since today I can not open a DWG file (16MB) from yesterday. Sketchbook
shows an Error Prompt:
Autodesk product failed to send the required value for SERIALNUM
It is possible to open and save other files but I need to open this one or convert
it to a working file.
Hope you can help me
3 REPLIES 3
TravisNave
in reply to: washout13
Welcome to the community.  If you think you can zip and attach the DWG, perhaps it can be fixed.  That is, if it is not sensitive data that you don't want to share.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
washout13
in reply to: TravisNave
Hallo,
I tried to send the file but unfortunately it is 16 mb and could not
be sent. Is there a way so I can fix the file myself?
Daniel
TravisNave
You can try to audit and recover it in AutoCAD, perhaps.
Autodesk Forums:
Administrator Productivity
