Installation & Licensing
New Member
washout13
Message 1 of 4 (287 Views)
Can't open a saved DWG file in sketchbook Designer. "failed to send ...
287 Views, 3 Replies
08-15-2013 12:59 AM
I am using an edu Version of Sketchbook Designer 2014 on Win 8.
Since today I can not open a DWG file (16MB) from yesterday. Sketchbook
shows an Error Prompt:
Autodesk product failed to send the required value for SERIALNUM
It is possible to open and save other files but I need to open this one or convert
it to a working file.
Hope you can help me
TravisNave
Message 2 of 4 (273 Views)
Re: Can't open a saved DWG file in sketchbook Designer. "failed to send ...
08-15-2013 07:49 AM in reply to: washout13
Welcome to the community.  If you think you can zip and attach the DWG, perhaps it can be fixed.  That is, if it is not sensitive data that you don't want to share.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
washout13
Message 3 of 4 (265 Views)
08-16-2013 01:08 AM in reply to: TravisNave
Hallo,
I tried to send the file but unfortunately it is 16 mb and could not
be sent. Is there a way so I can fix the file myself?
Daniel
TravisNave
Message 4 of 4 (261 Views)
08-16-2013 09:13 AM in reply to: washout13
You can try to audit and recover it in AutoCAD, perhaps.
