Installation & Licensing
Can't open a saved DWG file in sketchbook Designer. "failed to send ...
3 REPLIES 3
780 Views, 3 Replies
I am using an edu Version of Sketchbook Designer 2014 on Win 8.
Since today I can not open a DWG file (16MB) from yesterday. Sketchbook
shows an Error Prompt:
Autodesk product failed to send the required value for SERIALNUM
It is possible to open and save other files but I need to open this one or convert
it to a working file.
Hope you can help me
3 REPLIES 3
TravisNave
Welcome to the community.  If you think you can zip and attach the DWG, perhaps it can be fixed.  That is, if it is not sensitive data that you don't want to share.
Autodesk Forums:
in reply to: TravisNave
Hallo,
I tried to send the file but unfortunately it is 16 mb and could not
be sent. Is there a way so I can fix the file myself?
Daniel
TravisNave
You can try to audit and recover it in AutoCAD, perhaps.
Autodesk Forums:
Administrator Productivity
