Installation & Licensing
Can`t installing 32 bit version on 64 bit system
6 REPLIES 6
alr0sh
6833 Views, 6 Replies
hello,
i got my version of inventor pro 2014
Unfortunately i download 32bit instead of 64bit
according to my knowledge setup 32bit version on 64bit system [ Windows 7 ] not big deal, it`s spouse to work well without any problems
but i got an error ..
" you are attempting to use a 32-bit installer on 64bit operating system .. "
is there any suggestions for solving this ?
expecting using virtual system or re-download 64bit version << i had rlly bad connection
More Info:
my system - windows 7 ultimate SP 1 x64
4 GB ram
AMD phenom II x6 1055T processor 2.8 GHz
Tags (3)
6 REPLIES 6
DarrenP
in reply to: alr0sh
you would need to download the 64 bit version
DarrenP
alr0sh
in reply to: alr0sh
no another solution ?
re-download will take 10 days or even more with my connection ..
and i have a project must work on it soon : (
pendean
in reply to: alr0sh
Do the right thing, grab the correct version (and a faster internet connection). You should be able to find it at the Autodesk Customer Service Virtual Agent:
1. Go to http://www.autodesk.com
2. Click on Contact Us at the bottom of the page
3. Click on Customer Service
4. Click on Virtual Agent “Ask”
5. Once the Virtual Agent window opens: Select the choice "Download Links".
6. Select your product, then variant, then version as applicable.
7. You should now be presented with the choice to download your software.
Or contact an Autodesk reseller in your region of the world and pay for next-day or same-day delivery of a disk set of your software.
alr0sh
in reply to: pendean
i guess i have no choice
ok, Thx for ur help ^^
RocketRac00n
in reply to: alr0sh
I see your system requirements here:
- 4 GB ram
- AMD phenom II x6 1055T processor 2.8 GHz
I was wondering if this build actually works out for you, because I need a new pc to work with AutoCAD on, because my specs"Intel Celeron 2.19 Ghz, 2gb of RAM , Windows 7 64 Bit is not working out for me. 😞
alr0sh
in reply to: RocketRac00n
its work, but mine is old now i guess. if u have a good budget, u can get build better than mine i don't think here the right place to discuses about that + I'm not that expert u think in customize pc build. so, i would recommend TEC forum like tomshardware or any another site u like will gives u information about what u want. good luck 🙂
Administrator Productivity
