We have purchased the IDS (Infrastructure Design Suite) Ultimate 2012 and I have been able to all components except for Storm & Sanitary Analysis 2012. Below is a portion of the instllation log:
2011/11/30:12:28:39 cfiorica BKW-WINXP64-01 === Setup started on BKW-WINXP64-01 by cfiorica ===
2011/11/30:12:28:39 cfiorica BKW-WINXP64-01 Launch
2011/11/30:12:29:49 cfiorica BKW-WINXP64-01 PageOpen LaunchDialog
2011/11/30:12:29:54 cfiorica BKW-WINXP64-01 PageOpen LicenseDialog
2011/11/30:12:29:57 cfiorica BKW-WINXP64-01 PageOpen ProductInfoDialog
2011/11/30:12:30:10 cfiorica BKW-WINXP64-01 PageOpen ProductSelectionDialog2
2011/11/30:12:30:39 cfiorica BKW-WINXP64-01 PageOpen FullProgressDialog
2011/11/30:12:30:39 cfiorica BKW-WINXP64-01 Installing Autodesk Storm & Sanitary Analysis 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/11/30:12:33:51 cfiorica BKW-WINXP64-01 Install Autodesk Storm & Sanitary Analysis 2012 Succeeded
2011/11/30:12:33:51 cfiorica BKW-WINXP64-01 Installing Autodesk Storm & Sanitary Analysis 2012 x64 PlugIn: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/11/30:12:34:22 cfiorica BKW-WINXP64-01 Install Autodesk Storm & Sanitary Analysis 2012 x64 PlugIn Failed Installation aborted, Result=1612
2011/11/30:12:34:50 cfiorica BKW-WINXP64-01 Rollback Autodesk Storm & Sanitary Analysis 2012 Succeeded
Notice the part in BOLD where it aborts while trying to install the x64 plug-in. I am running Windows XP 64 with all the updates possible installed. Please help...we really need to get it going.
Carl Fiorica
Windows Installer Error 1612 :
The installation source for this product is not available. Verify that the source exists and that you can access it.
You might check to see that the installation files are available. If you are installing from media, copy to your HDD and install from there.
It does ask for the location of the plug-in and I am able to direct it to where it is located on the media. Will try to copy and install from the hard drive.
Sounds good. Make sure that you are installing with admin rights and anti-virus disabled. Good Luck!
Worked! Thanks. Crazy thing.
