It installs, then when I click on the icon (or try to run it), says:
The application failed to initialize properly (0xc000007b).
I'm installing on a Vista/Dell.
Would appreciate some help, thanks
Alley
OK still waiting for help. This isn't the easiest site to maneuver. I just want to install the software I bought. I'd heard so much good stuff about it. It says it works for Vista yet it's not installing. Did I waste my money? I planned on buying 2 more copies for my kids and I had hoped to work on my project this week, but the week is passing and I'm still waiting for an answer. I'm not a computer guru. I just want it to work or I can send it back and buy something else.
Thank you,
Pat Hauldren
alleypat@tx.rr.com
try right clicking the icon and run as administrator
DarrenP
did you have any anti virus software running while installing?
DarrenP
no you need to make sure it wasn't running when installing
DarrenP
this is most likely an OS issue or a hardware issue or your anitvirus software is blocking the program
DarrenP
you shouldn't have to unless it tells you to
DarrenP
try sending an email to autodesk: SketchBook.help@Autodesk.com
DarrenP
for me, since 3 days ago a message popping up
""object already exist""
i cant delete the august windows security update, due , its not exist
i already set all possible permisson
also set permission on crypto >> keys folder
i ran the tweaking sw , and find no error no where
i using win 7 home premium
windows activated
i made clean boot, with stopped all non windows service
im very open all possible solution..
i also like to hear some autodesk opinion
best regard
viktor
some update
after deleted all windows security updates, beyond aug , means all august and september updates, computer worked faster and i could install with no any issue..
beta testers should check after each windows update , make sure programs still working.. should save a lot headache for upcoming new users..
