Installation & Licensing
can't install SketchBookPro
18 REPLIES 18
Message 1 of 19
1594 Views, 18 Replies
It installs, then when I click on the icon (or try to run it), says:
The application failed to initialize properly (0xc000007b).
I'm installing on a Vista/Dell.
Would appreciate some help, thanks
Alley
18 REPLIES 18
Message 2 of 19
OK still waiting for help. This isn't the easiest site to maneuver. I just want to install the software I bought. I'd heard so much good stuff about it. It says it works for Vista yet it's not installing. Did I waste my money? I planned on buying 2 more copies for my kids and I had hoped to work on my project this week, but the week is passing and I'm still waiting for an answer. I'm not a computer guru. I just want it to work or I can send it back and buy something else.
Thank you,
Pat Hauldren
alleypat@tx.rr.com
Message 3 of 19
DarrenP
try right clicking the icon and run as administrator
DarrenP
Message 4 of 19
in reply to: DarrenP
even though I'm logged in as administrator? I'll try that, thanks. I'll have to reinstall it.
Message 5 of 19
nope, still same error message
Message 6 of 19
DarrenP
did you have any anti virus software running while installing?
DarrenP
Message 7 of 19
Yes, but I exited it to try that and didn't work. Do I have to remove the virus program? (It's AVG)
Message 8 of 19
DarrenP
no you need to make sure it wasn't running when installing
DarrenP
Message 9 of 19
ok I'll give it a go, thanks
Message 10 of 19
DarrenP
this is most likely an OS issue or a hardware issue or your anitvirus software is blocking the program
DarrenP
Message 11 of 19
after disabling, I should reboot before reinstalling?
Message 12 of 19
DarrenP
you shouldn't have to unless it tells you to
DarrenP
Message 13 of 19
ok, disabled virus scanner pgm, re-installed, ran as administrator, same error msg.
Message 14 of 19
DarrenP
try sending an email to autodesk: SketchBook.help@Autodesk.com
DarrenP
Message 15 of 19
ok thanks
Message 16 of 19
tyejay
Hi There,
DarrenP is correct. Please email sketchbook.help@autodesk.com This dedicated sketchbook support team should be able to assist you.  Thank you.
Jay Tye
Customer Service & Support
AUTODESK
Message 17 of 19
in reply to: tyejay
Yes, I mailed them. They have no idea, just say it's the OS. The OS is Vista and it's up to date.
Message 18 of 19
cnccarving
for me, since 3 days ago  a message popping up
""object already exist""
i cant delete  the  august windows security update, due , its not exist
i already set all possible permisson
also set permission on crypto >> keys folder
i ran the  tweaking sw  , and find no error no where
i using win 7 home premium
windows activated
i made clean boot, with stopped all non windows  service
im very open all possible solution..
i also like to hear some autodesk opinion
best regard
viktor
Message 19 of 19
cnccarving
in reply to: cnccarving
some update
after deleted all windows security updates, beyond aug , means all august and september updates, computer worked faster and i could install with no any issue..
beta testers should check after  each windows  update , make sure  programs still working.. should save a lot headache for  upcoming new users..
Administrator Productivity
