Installation & Licensing
Can`t install Robot structural analysis
8 REPLIES 8
Message 1 of 9
espen.kleiven
3282 Views, 8 Replies
Hoping anyone can help me on this problem.
I have downloaded Robot structural analysis from autodesk, but when i click setup, a message appears, telling me "the system cannot find the path spesified C:Users\...\Appdata\local\temp\_AI49FF.tmp\x64\RSA\RSA.msi" And the installation aborts after.
How on earth may i fix this?
8 REPLIES 8
Message 2 of 9
TravisNave
in reply to: espen.kleiven
Try installing it as another user.  Make sure you have local admin rights, UAC is off, and anti-virus is temporarily disabled.
Autodesk Forums:
Message 3 of 9
a0034858
doesn't work. what's interesting is i installed autodesk simulation multiplhysics 2013 on the same computer without any hiccups.
Message 4 of 9
I have the same exact problem, does anyone have a solution?
Message 5 of 9
WindData
I have same issue. Attempting to install 2013 pro, missing RSA.mis file.
Tried some of the hotfix to no avail....
Any solution for this is appreciated...
Message 6 of 9
WindData
in reply to: TravisNave
Message 7 of 9
MESASIVA
hello sir. please help me. I have downloaded Robot structural analysis from autodesk, but when i click setup, a message appears, telling me "the system cannot find the path spesified C:Users\...\Appdata\local\temp\_AI49FF.tmp\x64\RSA\RSA.msi" And the
Message 8 of 9
tnet13
I also experince this problem, tried to disable windows defender, turn off smartscreen as you suggest, and as a new user, nothing helps. Btw i can not start the install of the 2014 version of RSA, when using the website nothing happens after you click "install now", the window simply closes down again, tried with both chrome and IE, which is why i went and downloaded the 2013 version. Any kind of solution would be appreciated
Message 9 of 9
tnet13
in reply to: tnet13
I seem to have found a solution myself, the installation of RSA 2014 version did not work because the language was set to "english", selecting to install all the languages triggered the install procedure and the 2014 edition did not end with the error when launching the setup.exe. Hope this helps anyone else.
Administrator Productivity
