Installation & Licensing
Can't Install Revit MEP 2012...
21 REPLIES 21
Message 1 of 22
LisaDrago
2132 Views, 21 Replies
Hello - I have downloaded revit MEP 2012 from the subscription center.
I have tried to install it 3 times now and it gets to where it is installing the last part - and it just hangs. I have left it run for over an hour so i know it is hung up.
I have cleaned off all the files and tried it again and i get no where.
Win 7 pro - 32 bit.
Please help... I installed Revit Architectue fine and Revit Structure okay (not recognizing my license number have already sent a request for that) so Revit MEP is the last i need to install.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
21 REPLIES 21
Message 21 of 22
jsk307
in reply to: LisaDrago
yesterday i downloaded revit MEP2012 software, when i am trying to install, it shows that an error has been occured duribg the installation
some times it gives an error that "ERROR1722"& "ERROR1935" LIKE THAT,,,So please give me a solution to resolve.thank you..
Message 22 of 22
TravisNave
in reply to: jsk307
Post your installation log file.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
