Installation & Licensing
can't install revit architecture 2012 after uninstalling revit 2013
2 REPLIES 2
miyuanankie
1380 Views, 2 Replies
Hi, can anyone help me out? I uninstalled revit 2013 and tried to install revit architecture 2012 but it didn't work out. I followed the instruction deleting both TEMP files and Windows registry files.
Here's the installation log file.
2012/10/5:16:42:03 Administrator ANKIE-PC === Setup started on ANKIE-PC by Administrator ===
2012/10/5:16:42:03 Administrator ANKIE-PC Launch
2012/10/5:16:43:11 Administrator ANKIE-PC === Setup ended ===
2012/10/5:16:42:04 Administrator ANKIE-PC === Setup started on ANKIE-PC by Administrator ===
2012/10/5:16:42:04 Administrator ANKIE-PC Launch
2012/10/5:16:42:05 Administrator ANKIE-PC [Error: 1052] The requested control is not valid for this service.
2012/10/5:16:43:13 Administrator ANKIE-PC PageOpen LaunchDialog
2012/10/5:16:43:26 Administrator ANKIE-PC PageOpen LicenseDialog
2012/10/5:16:43:31 Administrator ANKIE-PC PageOpen LaunchDialog
2012/10/5:16:49:01 Administrator ANKIE-PC PageOpen LicenseDialog
2012/10/5:16:49:35 Administrator ANKIE-PC PageOpen ProductInfoDialog
2012/10/5:16:49:53 Administrator ANKIE-PC PageOpen ProductSelectionDialog2
2012/10/5:16:50:23 Administrator ANKIE-PC PageOpen FullProgressDialog
2012/10/5:16:50:24 Administrator ANKIE-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/10/5:16:50:27 Administrator ANKIE-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2 REPLIES 2
aaronhai
in reply to: miyuanankie
TravisNave
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
Administrator Productivity
