Solved by pendean. Go to Solution.
Hi L Z and welcome to the Autodesk Community!
AutoCAD LT 2010 is designed to work optimally on Windows XP or Vista. You may want to try running your Windows 7 in XP Mode as an alternative. Hopefully that works for you, if you have any other questions please respond to this post. Thank you!
You probably downloaded only the 32bit and now you need the 64bit version. You should be able to find it at the Autodesk Customer Service Virtual Agent:
1. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
2. Select the choice "Download Links".
3. Select your product, then variant, then version as applicable.
4. You should now be presented with the choice to download your software.
5. Save the download somewhere safe, it won't be available on the Autodesk website much longer.
For direct licensing assistance please contact our Activation and Registration department through our Contact Us page. Select your issue, topic, and then "I still need help" to pull up the associated chat options. Thanks!
