Installation & Licensing
Member
romtinerfani
Message 1 of 12 (1,241 Views)
Can't install Mudbox 2013...
1241 Views, 11 Replies
04-09-2013 02:35 PM
Hi guys,
I'm trying to install the 64 bit version of Mudbox for Windows 7. I run the setup, enter the product key and set a custom location but it keeps failing immediately and I get this message:
I tried selecting the 30-day trial instead and not changing the default install location, but no good. It just keeps failing to install.
Here's a copy/paste of the log file, dunno if it's very helpful:
2013/4/9:14:24:48    Romtin    ROMTIN-PC    === Setup started on ROMTIN-PC by Romtin ===
2013/4/9:14:24:48    Romtin    ROMTIN-PC    Launch
2013/4/9:14:24:48    Romtin    ROMTIN-PC    PageOpen    LaunchDialog
2013/4/9:14:24:55    Romtin    ROMTIN-PC    PageOpen    LicenseDialog
2013/4/9:14:24:57    Romtin    ROMTIN-PC    PageOpen    ProductInfoDialog
2013/4/9:14:25:20    Romtin    ROMTIN-PC    PageOpen    ProductSelectionDialog2
2013/4/9:14:25:22    Romtin    ROMTIN-PC    PageOpen    FullProgressDialog
2013/4/9:14:25:22    Romtin    ROMTIN-PC    Installing Autodesk® Mudbox® 2013:  TRANSFORMS="C:\Users\Romtin\AppData\Local\Temp\_AIFB02.tmp\x64\Mudbox\Mudbox2013.0-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="M:\mudboxInstall\" INSTALLDIR="C:\Program Files\Autodesk\Mudbox 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/4/9:14:25:23    Romtin    ROMTIN-PC    Install    Autodesk® Mudbox® 2013    Failed    Installation aborted, Result=1603
DarrenP
Message 2 of 12 (1,236 Views)
Re: Can't install Mudbox 2013...
04-09-2013 02:58 PM in reply to: romtinerfani
read this: http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
a 1603 error is a generic windows error that can be caused by multiple things with multiple solutions
Member
romtinerfani
Message 3 of 12 (1,207 Views)
04-09-2013 07:48 PM in reply to: DarrenP
thx darren,
i don't have issues with prerequisites like C++ or .NET failing. I even altered the .ini (setup) file to not search for those and it still failed. actually the prerequisites don't even show up all i see is mudbox failing.
I turned UAC off and I'm running as admin on my computer (plus I'm the only user). I have no anti-virus software and I turned off my Windows firewall... Still didn't work. I also tried using default location for install and selected NO Service pack but no good...
I tried Maya 2013 as well, and it failed too. Same issue.
Anyone, please!
DarrenP
Message 4 of 12 (1,145 Views)
04-10-2013 05:59 AM in reply to: romtinerfani
TravisNave
Message 5 of 12 (1,130 Views)
04-10-2013 03:29 PM in reply to: romtinerfani
Try installing as a different user with admin rights.
Member
romtinerfani
Message 6 of 12 (1,118 Views)
04-10-2013 09:20 PM in reply to: TravisNave
just got back home not too long ago...
tried running in windows diagnostic as per those linked instructions, Darren. didn't work..
now I guess I'll make a new user with admin priviledges on my computer and try Travis' idea.
I never mentioned I already have Maya 2012 (student edition) on this computer. Installed it back in August last year with no problems whatsoever. Could that be the problem? I can't afford to risk uninstalling that, I go back to school on Monday and I need it.
Replies, anyone and everyone, please:smileyhappy:
Member
romtinerfani
Message 7 of 12 (1,109 Views)
04-10-2013 11:08 PM in reply to: romtinerfani
AWESOME! thank you so much Travis. I made a separate user account with admin priviledges and ran the install. i literally gasped when the install bar stayed on the screen and Mudbox successfully installed. I chose to manually install the service packs, but that didn't take more than a few seconds.
Again, this had been driving me nuts since Monday night so thank you so much everyone!!
TravisNave
Message 8 of 12 (1,099 Views)
04-11-2013 05:09 AM in reply to: romtinerfani
Excellent. Glad you are up and running.
Member
_AKS_
Message 9 of 12 (989 Views)
06-03-2013 02:08 AM in reply to: romtinerfani
Delete "C:\ProgramData\Autodesk\AdLM\ProductInformation.pit". I may solve your problem.
TravisNave
Message 10 of 12 (975 Views)
06-04-2013 07:15 AM in reply to: _AKS_
This is a closed thread, and deleting this file has no impact on the problem by the OP.  This file should never be deleted unless there is a licensing error preventing activation or installation due to the corruption of that file. It will be obvious if it needs to be deleted by the error.  If you delete this file, you will lose activation for all of the Autodesk products installed on your machine.  It should only be done as a last resort and for the specific problem that is needed.
If you wish to help on the boards, we welcome it.  However, please assist current and unsolved questions with specific known solutions to the problem.
Thanks.
