I am unable to install AUD 2014. After checking the task manager, it seems that the setup.exe program runs, then quits with no error.
I have the anti-virus software's on-access scanning disabled and UAC is turned off.
I have local admin access to the PC and have also tried the "Run as administrator" menu item.
I have tried logging in with another account which also has local admin access.
I have a 64-bit system and am using the 64-bit disc.
I have tried downloading the trial version from the website, but get the same results.
Any help is appreciated. Thanks!
Hmm, Do you happen to have a software installed called "Displaylink Core Software"? That has been known to cause our setup.exe to crash.
I don't have that particular software installed, and I could not find the .dll mentioned in the link either.
Hmm I am not sure what might be happening. Are you getting any screens at all? At what point is the install crashing?
Yes, it's quite perplexing. When I start the installer, I can hear the DVD drive spin up, but I never see anything. If I watch the task manager closely, I can see "Setup.exe * 32" in the list, then a few seconds later, it's gone with no errors and no messages of any kind. I've also checked in the Windows event log, but wasn't able to see anything in there either. I've also tried copying the files from the DVD to the local hard drive, but that didn't work.
Windows 7 Professional, 64-bit (Service Pack 1 is installed)
Sophos Endpoint Security & Control, version 10.0
Sorry I am not sure what might be going on. Can you check if it's creating any log files? The logs will be generated in the TEMP directory which can be accessed by typing '%temp%' in the START > RUN. Please locate the logs which will have a naming convention of "Product Name Setup.log" and "Product Name Install.log" , where "Product name" is the name and release year of the software.
I found the log files, but it appears that no data is being written to them. The dates in the files are all from several months ago when I had AUD installed before. However, it doesn't appear that anything is being written to the logs this time as the file sizes are all identical, even after starting the setup program several times.
