I am trying the AutoCad 2015 download for students and for some reason I can't get it to install on my 64-bit Windows 7 laptop. From what I have read, I have enough space for the download and I have all of the system requirements. I just can't figure out why this won't work! I have attached a picture of what happens after the "installation" happens. Little red x's next to each product saying they have failed to install.
Please help, need this for engineering class!!!
Solved by natasha.l. Go to Solution.
Hi @Anonymous and welcome to the Autodesk Community!
Thanks for the screenshot but if you could please reply with an attachment of your installation log file I would be happy to troubleshoot further. Thanks!
Hi all!
Please try re-downloading your software following the steps below:
If the problems persist please reply to my post with further details on the exact issue you're experiencing. Thanks!
Hi
- In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
- In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
- Turn off your personal firewall or VPN, if you use one.
- Disable UAC
- Close and reopen your preferred browser.
- Re-download from the Virtual Agent
I tried it but still the same problem.
hi, can someone help me with this please? dont understand why and what is going on.
Can you use the Windows Snipping tool and capture only the relevant portion of the screen - I can't read anything in your image.
I fail to install audocad 2014, 32bits student version. I try many times and have the same problem. Please help, the quiz is next week.
2015/11/4:22:48:12 aaconloh AACON === Setup started on AACON by aaconloh ===
2015/11/4:22:48:12 aaconloh AACON Path_Length: 155
2015/11/4:22:48:12 aaconloh AACON Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2015/11/4:22:48:12 aaconloh AACON Launch
2015/11/4:22:48:12 aaconloh AACON CommandLine /PK 001F1 /SN 900-64116692 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup....
2015/11/4:22:48:12 aaconloh AACON Current Directory C:\Users\aaconloh\AppData\Local\Temp\_AIA288.tmp
2015/11/4:22:48:13 aaconloh AACON === Setup ended ===
2015/11/4:22:48:13 aaconloh AACON Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64....
2015/11/4:22:48:13 aaconloh AACON Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\aaconloh\AppData\Local\Temp\_AIA288.tmp\Setup\AcSetup.dll
2015/11/4:22:48:13 aaconloh AACON Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/11/4:22:48:13 aaconloh AACON PageOpen LaunchDialog
2015/11/4:22:48:18 aaconloh AACON PageOpen LicenseDialog
2015/11/4:22:48:18 aaconloh AACON PageOpen ProductInfoDialog
2015/11/4:22:48:18 aaconloh AACON PageOpen ProductSelectionDialog2
2015/11/4:22:48:59 aaconloh AACON PageOpen FullProgressDialog
2015/11/4:22:49:00 aaconloh AACON Download Skipped DOTNET4LANG http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DOTNET4KB2...
2015/11/4:22:49:00 aaconloh AACON Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q
2015/11/4:22:49:12 aaconloh AACON Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
Hi can someone help me, I can't install autocad also on my laptop using windows 64 bit. It says aborted when I install it.
What does this mean?
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
@Anonymous
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
WARNING: This is a worldwide public user community and it's important that you do not include/share your serial # in your posting/attachments. I will have the moderator remove your serial # in order to protect your information. For the future please keep that rule in mind.
Don't use that method...
Click on the “installation” link in my signature and follow the recommended steps that are provided in that posting. Make sure to review all of the acceptable solutions (marked in green) since these steps will change over time.
For example the most recent solution now includes a link to the major 2017 product line making it easier for the end user to download/install the latest version of the software.
If your installation does fail after these recommended steps
• Review this posting: http://forums.autodesk.com/t5/installation-licensing/how-to-determine-errors-in-installation-log-file/m-p/5283115
• If that doesn’t help, attach your installation log file here in a text file format and someone will review it for you. You can also locate your installation log file based on this posting: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Using-log-to-troubleshoot-installation-errors.html
• When attaching your installation log file make sure that any personal information such as your serial # is removed.
Good luck on your installation and hopefully this information will resolve your issue.
Mark Lancaster
& Autodesk Services MarketPlace Provider
i having same problem also
