Installation & Licensing
Can't install AutoCAD 2012 because 4.5 net framework is installed.
12 REPLIES 12
Message 1 of 13
modulcad
13629 Views, 12 Replies
I cannot install AutoCAD 2012 because installation of .net 4.0 fails. Direct installation of .net 4.0will not occure because higher version (.net framework 4.5) has aleady been installed on my computer (while installing Visaul Studio 2011 Preview).
Do you have any suggestion?
Juraj Lutisan
modulCAD Ltd.
12 REPLIES 12
Message 2 of 13
david.lau
in reply to: modulcad
You may need to research on how to uninstall .NET 4.5.  This looks like a developer preview of it.
http://www.microsoft.com/download/en/details.aspx?id=27537
David Lau
Message 3 of 13
modulcad
But our new product is based on .net 4.5 so I cannot uninstall it. Can I reinstall .net 4.5 after AutoCAD installation? Will be AutoCAD 2012 still functional?
Message 4 of 13
david.lau
You can try that but it is unsupported.  Please let us know...this is an interesting problem.
David Lau
Message 5 of 13
in reply to: david.lau
Me too , I can't install AutoCad becuse framework 4.5 . please fix install file !
Message 6 of 13
pendean
Uninstall Frameworks 4.5, install AutoCAD, reinstall 4.5 and see what happens: that's what the Autodesk folks above are suggesting. Not sure what else you want them to do at this stage.
You can, if you feel lucky, try and edit the AutOCAD installer to skip over the NET4 installation process: another more elaborate option.
Message 7 of 13
in reply to: pendean
I can't uninstall framework 4.5 . This is default on windows 8 . I was test all software that uninstall framework but I can't uninstall it.
Now , I have 2 frameworks , one is 3.5 and one is 4.5 . I can uninstall framework 3.5 but 4.5 , I can't .
Message 8 of 13
pendean
Read the post from TravisNave in this thread:
http://forums.autodesk.com/t5/CAD-Managers/Anyone-try-Windows-8-Developer-preview/td-p/3349977
You're ahead of the curve, you're pretty much on your own until Win8 is officially released and supported: so you need to be open minded about work-arounds and do them.
Message 9 of 13
TravisNave
Keep in mind that AutoCAD 2012 is not supported on Windows 8.  However, I was able to get it installed successfully.  I posted my steps on Dean's post here:
http://forums.autodesk.com/t5/CAD-Managers/Anyone-try-Windows-8-Developer-preview/m-p/3352895#M84974
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 10 of 13
Alexey.Terno
I have AutoCAD Civil 3D 2012 on my laptop. After installing Visual Studio 2011 with .NET 4.5 Civil3D won't work correctly - fatal errors after opening any dialogs in Civil3D... I had to uninstall VS2011 and .NET 4.5 to reinstall .NET 4.0 for Civil3D repair.
Message 11 of 13
fhil__
La version mas compatible con net framework 4.5 es la version de autocad 2013. Aunque trabaja mejor con net framework 4 aqui los detalles de y los requerimientos para el programa.
http://imaginit.com/software-solutions/process-plant/autocad/2013_autocad_2013_system_requirements_e...
Message 12 of 13
rasamad
I installed Autocad 2012 with .net framework 4.0, upgraded to 4.5 and cad stopped working. It crashed everytime I tried to open it. I uninstalled and tried in vain to reinstall it because now 4.5 is installed.
NEED HELP please!!
Message 13 of 13
david.lau
in reply to: rasamad
Can you try to uninstall .NET 4.5?
David Lau
Administrator Productivity
