my problem is that i can't install the software autocad 2011
my computer is running windows vista, a 64bit version, and I've also taken the 64bit installation dvd
there's no problem with the licence, and setup also starts to install the software, but it breaks up after 2 minutes and then there's the announcement installation failed (that's my translation, I wanted to install the german version, there it sais "Installation fehlgeschlagen")
this is from the setup editor (I tried several times)
2010/11/5:13:54:46 Corn CORN-PC === Setup started on CORN-PC by Corn ===
2010/11/5:13:56:13 Corn CORN-PC === Setup ended ===
2010/11/5:13:55:58 Corn CORN-PC === Setup started on CORN-PC by Corn ===
2010/11/5:14:01:00 Corn CORN-PC Install Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1603
2010/11/5:14:02:55 Corn CORN-PC Install Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1603
2010/11/5:14:05:11 Corn CORN-PC === Setup started on CORN-PC by Corn ===
2010/11/5:14:05:11 Corn CORN-PC Es wird bereits eine Instanz des Setups ausgeführt. Es kann nur jeweils eine Instanz des Setups ausgeführt werden.2010/11/5:14:05:16 Corn CORN-PC === Setup ended ===
2010/11/5:14:07:34 Corn CORN-PC === Setup ended ===
2010/11/5:14:12:04 Corn CORN-PC === Setup started on CORN-PC by Corn ===
2010/11/5:14:12:54 Corn CORN-PC === Setup ended ===
2010/11/5:14:12:39 Corn CORN-PC === Setup started on CORN-PC by Corn ===
2010/11/5:14:13:09 Corn CORN-PC Sie können auf dem aktuellen Betriebssystem dieses Produkt nicht installieren.2010/11/5:14:13:26 Corn CORN-PC Sie können auf dem aktuellen Betriebssystem dieses Produkt nicht installieren.2010/11/5:14:13:32 Corn CORN-PC === Setup ended ===
2010/11/5:14:17:36 Corn CORN-PC === Setup started on CORN-PC by Corn ===
2010/11/5:14:19:08 Corn CORN-PC === Setup ended ===
2010/11/5:14:18:52 Corn CORN-PC === Setup started on CORN-PC by Corn ===
2010/11/5:14:21:12 Corn CORN-PC Install Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1603
2010/11/5:14:28:07 Corn CORN-PC === Setup ended ===
thanks for helping
You'll likely need to install the Microsoft Visual C++ 2008 Redistributable manually from Microsoft first, as it is failing on installing this prerequisite.
I'm sorry but i can't install Microsoft Visual C++ 2008 Redistributable manually, there is an installing error occuring. I've tried it several times. what else can I try??
