Installation & Licensing
Can't install AC Mechanical
2 REPLIES 2
lkastelik
421 Views, 2 Replies
Hi, I have installed AC and Inventor Pro 2013 on my computer but the AC Mechanical install fails.
There is the txt file contents:
AEPTOSHIBA is the computer name and temp is the username. Im running Win7 HP x64. The computer is quite new and meets the min requirements.
Spoiler
2013/1/26:14:07:18 temp AEPTOSHIBA === Setup started on AEPTOSHIBA by temp ===
2013/1/26:14:07:18 temp AEPTOSHIBA Launch
2013/1/26:14:08:01 temp AEPTOSHIBA === Setup ended ===
2013/1/26:14:07:21 temp AEPTOSHIBA === Setup started on AEPTOSHIBA by temp ===
2013/1/26:14:07:21 temp AEPTOSHIBA Launch
2013/1/26:14:07:44 temp AEPTOSHIBA PageOpen LaunchDialog
2013/1/26:14:07:48 temp AEPTOSHIBA PageOpen LicenseDialog
2013/1/26:14:07:52 temp AEPTOSHIBA PageOpen ProductInfoDialog
2013/1/26:14:10:41 temp AEPTOSHIBA PageOpen ProductSelectionDialog2
2013/1/26:14:46:35 temp AEPTOSHIBA PageOpen FullProgressDialog
2013/1/26:14:46:35 temp AEPTOSHIBA Installing DirectX Runtime: C:\Users\temp\Desktop\acm\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/26:14:48:26 temp AEPTOSHIBA Install DirectX Runtime Succeeded
2013/1/26:14:48:32 temp AEPTOSHIBA Installing AutoCAD® Mechanical 2013: TRANSFORMS="C:\Users\temp\Desktop\acm\x64\pl-pl\acadm\acad.mst;C:\Users\temp\AppData\Local\Temp\_AI25E7.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=pl-pl ADSK_SOURCE_ROOT="C:\Users\temp\Desktop\acm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/26:15:01:28 temp AEPTOSHIBA Install AutoCAD® Mechanical 2013 Failed Installation aborted, Result=1603
2013/1/26:15:01:28 temp AEPTOSHIBA Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/26:15:01:39 temp AEPTOSHIBA PageOpen InstallCompleteDialog
2013/1/26:15:04:17 temp AEPTOSHIBA === Setup ended ===
2013/1/26:15:04:32 temp AEPTOSHIBA === Setup started on AEPTOSHIBA by temp ===
2013/1/26:15:04:32 temp AEPTOSHIBA Launch
2013/1/26:15:05:40 temp AEPTOSHIBA === Setup ended ===
2013/1/26:15:04:48 temp AEPTOSHIBA === Setup started on AEPTOSHIBA by temp ===
2013/1/26:15:04:48 temp AEPTOSHIBA Launch
2013/1/26:15:05:18 temp AEPTOSHIBA PageOpen LaunchDialog
2013/1/26:15:05:46 temp AEPTOSHIBA PageOpen LicenseDialog
2013/1/26:15:05:52 temp AEPTOSHIBA PageOpen ProductInfoDialog
2013/1/26:15:07:49 temp AEPTOSHIBA PageOpen ProductSelectionDialog2
2013/1/26:15:09:12 temp AEPTOSHIBA PageOpen FullProgressDialog
2013/1/26:15:09:12 temp AEPTOSHIBA Installing DirectX Runtime: C:\Users\temp\Desktop\acm\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/26:15:10:07 temp AEPTOSHIBA Install DirectX Runtime Succeeded
2013/1/26:15:10:09 temp AEPTOSHIBA Installing AutoCAD® Mechanical 2013: TRANSFORMS="C:\Users\temp\Desktop\acm\x64\pl-pl\acadm\acad.mst;C:\Users\temp\AppData\Local\Temp\_AI8C77.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=pl-pl ADSK_SOURCE_ROOT="C:\Users\temp\Desktop\acm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/26:15:18:45 temp AEPTOSHIBA Install AutoCAD® Mechanical 2013 Failed Installation aborted, Result=1603
2013/1/26:15:18:46 temp AEPTOSHIBA Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Thx for help.
2 REPLIES 2
TravisNave
in reply to: lkastelik
Make sure that you do not already have another vertical flavor of AutoCAD installed into this directory or installation will fail:
Autodesk Forums:
Administrator Productivity
