Solved by adlerfg. Go to Solution.
I´m experiencing the same issue. I´m trying to install 3ds Max student Swedish version on a Mac running windows 8.1. I downloaded the software but I get a message (in Swedish). I'll try to translate. "Error, the path to the network is incorrect, is missing or otherwise is this path not available at the moment. Type the path again or contact the network administrator"
What should I do? Path to C: is on Bootcamp.
Thanks for your help.
Hello Adler and welcome to the Autodesk Community!
It's possible you're receiving this error because none of our products are supported on Windows 8.1. Is it possible for you to roll back to Windows 8?
Hello and thanks for your quick answer.
I think I have good news then. I had installed windows 8.1 only yesterday and I had many issues, but then I uppdated windows and video drivers and everything´s working just fine. 3ds Max is running very smooth.
Thanks once again 😄
i used windows 8.1 64bit. I can't installer 3ds max 2014. When i installed it 's display windows installer. When i click ok. then setup was fail. How to fix it?
Thank you.
Hi @khungdanxua and welcome to the community!
You may want to try re-downloading taking the precautions below:
Please let me know if this helps! If not, please reply with your installation log. Thank you!
