Installation & Licensing
robinu92
832 Views, 5 Replies
Can't install 3DS Max
I keep having trouble while I'm installing 3DS Max. I've tried two different versions, the 2010 & 2012 version. In both cases the installation failures. The error log shows the following:
2011/11/21:19:42:43    Gebruiker    GEBRUIK-00PDEP5    === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:19:42:46    Gebruiker    GEBRUIK-00PDEP5    === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:19:42:51    Gebruiker    GEBRUIK-00PDEP5    === Setup ended ===
2011/11/21:19:50:47    Gebruiker    GEBRUIK-00PDEP5    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
2011/11/21:19:51:15    Gebruiker    GEBRUIK-00PDEP5    === Setup ended ===
2011/11/21:20:02:36    Gebruiker    GEBRUIK-00PDEP5    === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:20:02:38    Gebruiker    GEBRUIK-00PDEP5    === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:20:02:43    Gebruiker    GEBRUIK-00PDEP5    === Setup ended ===
2011/11/21:20:04:26    Gebruiker    GEBRUIK-00PDEP5    === Setup ended ===
2011/11/21:20:06:16    Gebruiker    GEBRUIK-00PDEP5    === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:20:06:19    Gebruiker    GEBRUIK-00PDEP5    === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:20:06:23    Gebruiker    GEBRUIK-00PDEP5    === Setup ended ===
2011/11/21:20:09:54    Gebruiker    GEBRUIK-00PDEP5    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
How can I resolve this problem?
5 REPLIES 5
camilo.lemos
in reply to: robinu92
Hi Robinu92.
Can you please try the solution on this thread  and let us know if it works for you?
Thanks!
Camilo Lemos
robinu92
in reply to: camilo.lemos
Well I can't find both register keys and the cofigurationmanager does not show any Visual C++ installed, so I don't get it? By the way my PC runs on Windows 7.
camilo.lemos
Hi robinu92.
Sorry to hear the first solution did not work.
I will suggest you look at this thread, spcifically post number 7 is a good starting point to resolve your issue.
If this works, please hit "Accept as Solution" to help other users find the answer to this question!
Thank you.
Camilo Lemos
robinu92
Well the problem still in't resolved. First I don't know how to uninstall the vcredist files? I've tried to install the vcredist files but then I get a new error. The error says that I need to locate the source which contains the vredist.msi file. So where can I find this file?
e_azzam
hi, Try to unistall Mocrosoft c++ 2005 from controlpanel and reinstall
Arch.Esam azzam
Revit Architecture ACI
BIM Manager
VRAY Licensed Trainer
Administrator Productivity
