Solved by JoAnn_Hogan. Go to Solution.
It could be because you are trying to download 2012. Try downloading 2014?
Gave it a shot, still didn't work. I didn't try it before because I need 2012 specifically, but it appears neither works
Did you download the software allready and struggeling to activate or is it giving you the error when trying to download?
That a good idea. The trial will expire in 30days. In the meantime contact Autodesk and enquire about your serial to activate your software. They are the only one that can give you the serial number
