I upgraded to revit 2013 for most of our machines and bought 2 new building systems version in january ... and now have an issue. It seems as if one of the 2013 revit architecture keeps taking a building systems license. Is this a first come first serve basis for the license manager? When building systems logs on first there's no issue, but when revit architeture logs in, it automatcially takes a building systems license. Can I force it to take a regular license?
were the license files generated on the same day?
DarrenP
is building suite the only product in the license file
run the license file through here: www.licenseparser.com
DarrenP
were they all generated the same day?
it should say on the license parser website
DarrenP
are you sure your running revit archtecture and not revit from the building suite
DarrenP
yes, both different installs .... one machine I installed building design suites and the other revit architecture suite. One with the usb install, the other with disks.
can you post the debug log for the flex lm?
DarrenP
so I had eveybody restart there machines and now there's no issue ... go figure .... I even had the same people try and simulate what they did and no issue.
must have been a solar flare ...... thanks for all your help and sorry for taking your time.
if this happens again, I'll post the debug file.
