Installation & Licensing
jdukc
Message 1 of 15 (3,995 Views)
can't find license
3995 Views, 14 Replies
02-11-2011 07:21 AM
Hopefully someone has an answer for this .... I'm running the latest licenser manager with 9 licenses for revit 2011.  Every now and then a machine (the first one in the morning to boot up revit) will say A VALID LICENSE CANNOT BE OBTAINED FROM THE NETWORK LICENSE MANAGER.  I'll then reboot the server and everything is fine and everybody can get on and work.  This is hit or miss, every couple of days, every couple of weeks.
this was a vpn issue .. when ever anybody used the vpn it did something to the network license.  we moved the license manger to a different server.
TravisNave
Message 2 of 15 (3,988 Views)
Re: can't find license
02-11-2011 07:44 AM in reply to: jdukc
Was there an error number associated with this message?  The error number helps identify the problem.  However, it's probably due to network latency.  If you add a system environment variable called FLEXLM_TIMEOUT and give it a value of 1000000 it may resolve your issue.
For more detailed information, see this KB:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13744786&linkID=9243099
Valued Mentor
frhervet
Message 3 of 15 (3,971 Views)
Re : can't find license
02-11-2011 09:36 AM in reply to: jdukc
Next time you have the problem, Do a "Perform satus enquiry" on the server and give us the log file to see where can be the problem.
Franck Hervet
S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
jdukc
Message 4 of 15 (3,922 Views)
02-17-2011 06:36 AM in reply to: jdukc
OK so it happened again .... a user got a message dialogue box saying Your application was not able to obtain a license because the FLEXnet license server manager cuold not determine where to find the licensing data it needs.   and then A valid license couldn not be obtained by the network license manager Error [-15.10.10061]
The only thing that worked was to reboot the server, but I can't reboot the server everytime someone can't find the license.  I'm attaching the status enquiry file and the debug log.
DarrenP
Message 5 of 15 (3,911 Views)
02-17-2011 06:46 AM in reply to: jdukc
how many users does this happen to?
did you try the above suggestion?
jdukc
Message 6 of 15 (3,890 Views)
02-17-2011 08:35 AM in reply to: jdukc
Yes, tried the above suggestions .. but those suggestion don't really apply except for the one that says to rename the cascade file.
Valued Mentor
frhervet
Message 7 of 15 (3,884 Views)
02-17-2011 08:55 AM in reply to: jdukc
Have you both product on each pc ?
Franck Hervet
jdukc
Message 8 of 15 (3,871 Views)
02-17-2011 10:20 AM in reply to: jdukc
both as in autocad revit and another autocad product ?  that would be yes, we're running both autocad revit 2011 and autocad architecture 2011.
jdukc
Message 9 of 15 (3,862 Views)
02-17-2011 11:09 AM in reply to: jdukc
can the highlighted portion below be something ??
adskflex: Cannot read data from license server system.
The license server system appears to be running, but is not
responding If this persists, notify the System Administrator.
(The license server manager (lmgrd) and vendor daemon processes
should be terminated and restarted.)
Hostname:      CBLH-SERVER01
License path:  27000@CBLH-SERVER01;
FLEXnet Licensing error:-16,287
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".
TravisNave
Message 10 of 15 (3,850 Views)
02-17-2011 11:51 AM in reply to: jdukc
Yes.  Stop the license server.  Then close LMTOOLS.  Open the Task Manager and make sure that adksflex.exe and lmgrd.exe are all terminated.  Then relaunch LMTOOLS and restart the service.  Check the status to ensure that all errors are gone.  If not, repost results here.
