Installation & Licensing
Can't find AutoCAD 2012 please help
4 REPLIES 4
monikamittal
370 Views, 4 Replies
I want to put my AutoCAD 2012 program on another PC. I have looked at the trial section and see 2013, but I can´t find AutoCAD 2012. Where can I download AutoCAD 2012?. Will someone help me please?
Thanks.
4 REPLIES 4
TravisNave
in reply to: monikamittal
If you own the product under Subscription you should be able to download it from the Subscription center at http://subscription.autodesk.com.  You can also contact your Reseller for replacement media.  Otherwise, if you're lucky, Autodesk will provide you with a temporary download link.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
monikamittal
in reply to: TravisNave
a temporary download link would be great help.
philip.s
Here you go monikamittal. The following download links have been timed for 72 hrs.
AutoCAD 2012 32BIT - LINK
AutoCAD 2012 64BIT - LINK
AutoCAD 2012 MAC - LINK
Please let me know if there is anything else that we can do for you.
monikamittal
in reply to: philip.s
perfect, thank you!
Administrator Productivity
